[postgis-devel] Bump GDAL and Proj versions for PostGIS 3
Sandro Santilli strk at kbt.io
Tue Jul 16 00:08:15 PDT 2019
On Sat, Jul 13, 2019 at 09:54:45PM +0300, Darafei "Komяpa" Praliaskouski wrote:
> PR ready: https://github.com/postgis/postgis/pull/445
> At least Dronie has to upgrade at least Proj version for our CI to be
> green. I've fixed Travis already.
Docker image used by Dronie is built from this Dockerfile:
https://git.osgeo.org/gitea/postgis/postgis-docker/src/branch/master/build-test/Dockerfile.trisquel2
It installs libproj-dev from default packages found in
    Trisquel GNU/Linux 7.0, Belenos
We could install newer proj manually OR upgrade to a newer version
of that distribution. But - really - now we're in alpha stage, why
do we want to _restrict_ what a user can do ? The only advantage would
be for us, not for the users. Number of users is way bigger than
number of developers... (and Dronie is just one user having to deal
with this change)
--strk;
