[postgis-devel] 2.5.0beta2 build error against PostgreSQL 11 beta3
Raúl Marín Rodríguez
rmrodriguez at carto.com
Wed Jun 5 05:07:45 PDT 2019
Is the error the same?
In that case, the solution is still either disabling JIT or using CFLAGS
that compatible with both compilers (likely clang and gcc).
On Wed, Jun 5, 2019 at 2:03 PM Devrim Gündüz <devrim at gunduz.org> wrote:
> Hi,
> [Bringing back this old thread]
> On Thu, 2018-08-23 at 16:19 +0300, Darafei "Komяpa" Praliaskouski wrote:
> > You need to choose CFLAGS that are common between clang and gcc, as PostGIS
> > is being compiled by both, to support JIT. This is the same for any
> > extension of PG11.
> Any hints how? The PostGIS is failing to build on recent Fedora releases.
> Regards,
> Devrim Gündüz
> Open Source Solution Architect, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
carto.com
