[postgis-devel] 2.5.0beta2 build error against PostgreSQL 11 beta3
Devrim Gündüz
devrim at gunduz.org
Wed Jun 5 09:54:16 PDT 2019
On Wed, 2019-06-05 at 14:46 +0200, Raúl Marín Rodríguez wrote:
> If you don't want JIT at all, disable it when building postgres (`--with-
> llvm`).
(I do the packaging for the PostgreSQL RPM repo, and this is not an option
there :) )
> If you want JIT, you'll need to locate where was the flag (`-fcf-protection`)
> declared and remove it. It's either passed:
> - To Postgresql CFLAGS. In this case it'll appear in `pg_config --cflags`.
> - To postgis `./configure` as part of the CFLAGS env variable.
Ok, I'll remove that from CFLAGS in PostGIS.
So, why does 3.0 don't have this problem?
Regards,
Devrim Gündüz
Open Source Solution Architect, Red Hat Certified Engineer
Twitter: @DevrimGunduz , @DevrimGunduzTR
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190605/c44470b9/attachment.sig>
