[postgis-devel] gserialized-v2
Paul Ramsey
pramsey at cleverelephant.ca
Sat Jun 22 09:09:11 PDT 2019
> On Jun 22, 2019, at 9:08 AM, Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
> Do you need proj-6 for this or just postgresql-12-dev?
Neither, it’s orthogonal to both those.
P
> On Fri, Jun 21, 2019, 4:02 PM Paul Ramsey <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca>> wrote:
> So, the PR finally builds and regresses, and includes the initial
> scaffolding on which new features using new flagging can be built.
> https://github.com/postgis/postgis/pull/421 <https://github.com/postgis/postgis/pull/421>
> In order to get there, you'll note some structural changes around the code base
> - All access to gserialized internals is now behind an API that lives
> in gserialized.c
> - The homology between gserialized->flags and lwgeom->flags is now
> broken -- gserialized2 has an 8-bit gflags member, and an optional
> 64-bit xflags area managed behind the api, while lwgeom->flags has
> been expanded to 16 bits for now, with room potentially to get to 24
> with some extra contortions as necessary in the future
> - That means you can continue to call FLAGS_SET/GET macros on
> lwgeom->flags, but you should no longer assume you can do so on
> gserialized->gflags, you should instead call the relevant
> gserialized_get_*() functions from the API
> - (All the above changes have been cleaned out of the code base, so
> this in on a going forward basis, there is no work to be done by
> anyone to implement the above, it's already done)
> - lwgeom_from_gserialized() will magically work regardless of whether
> it's fed a v1 or v2 serialization, so this code all works fine when
> slapped on top of a database full of old geometries
> - gserialized_from_lwgeom() (and the two functions riding on top of
> it, geometry_serialize() and geography_serialize(), which are
> preferred when calling from inside ./postgis) will write out v2
> geometries, so databases will slowly get re-written with the new form
> over time
> So far all this deck chair rearranging has resulted in no net-new
> functionality. I'm looking at two potential areas where the new
> serialization could be put to use before postgis3:
> - The extra flag space on gflags that has been freed up by moving the
> IsSolid flag into the xflags area could be used of an IsPoint flag, to
> allow a lightweight point type. A lightweight x/y point could then be
> 24 bytes (varsize + srid/flags + x + y) instead of 32 bytes (varsize +
> srid/flags + type + padding + x + y), for a 25% savings for simple
> points.
> - An extended flag and optional data area to hold a hash code could be
> used to accelerate the prepared geometry cache for those cases where
> the cached object is large, avoiding much of the current repetitive
> decompression overhead.
> - Some kind of validity caching could be put into place for larger
> objects using a ValidChecked/IsValid pair of flags in the extended
> area. open question for me would be -- when to set those flags, what
> triggers it? obviously ST_MakeValid() could set it, but what about
> automatically for any large polygons during serialization?
> I apologize in advance for the fundamental ugliness of the work, I'm
> not an artist, I'm a tradesman.
> ATB,
> P
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-devel <https://lists.osgeo.org/mailman/listinfo/postgis-devel>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190622/a02b29c7/attachment-0001.html>
