[postgis-devel] PSC Vote: PostGIS 3.0 alpha3 release this weekend?
Regina Obe
lr at pcorp.us
Fri Jun 28 13:27:19 PDT 2019
>> Subject: Re: [postgis-devel] PSC Vote: PostGIS 3.0 alpha3 release this weekend?
>> Re: Regina Obe 2019-06-27 <001d01d52cf1$0beed680$23cc8380$@pcorp.us>
>> except for that annoying 32-bit failure on FreeBSD 32-bit and widnows
>> 32-bit (which I assume is a failure on all 32-bits) - would be nice to
>> either change the test or fix before alpha3 release
>> 32-bit fails on Linux as well: https://trac.osgeo.org/postgis/ticket/4407
>> Christoph
I'm not seeing the above error on windows 32-bit or FreeBSD 32-bit.
The one I was referring to is this one which is a new test for full-join introduced in alpha3dev
https://trac.osgeo.org/postgis/ticket/4433
1:58:36 tickets .. failed (diff expected obtained: /home/jenkins/tmp/pgis_reg_f9334cb0058fc5a796335d219109738a0d1e9ae5/test_98_diff)
21:58:39 -----------------------------------------------------------------------------
21:58:39 --- tickets_expected 2019-06-22 21:51:32.916336000 -0400
21:58:39 +++ /home/jenkins/tmp/pgis_reg_f9334cb0058fc5a796335d219109738a0d1e9ae5/test_98_out 2019-06-22 21:57:58.244904000 -0400
21:58:39 @@ -390,3 +390,4 @@
21:58:39 ERROR: BOX2D_construct: args can not be empty points
21:58:39 #4176|t
21:58:39 #4394
21:58:39 +#4394
