[postgis-devel] Support Functions
Paul Norman penorman at mac.com
Tue Mar 5 12:50:11 PST 2019
On 2019-03-03 12:47 a.m., Sandro Santilli wrote:
> By enforcing use of an index are we reducing flexibility ?
Yes.
> IIRC in the topology code we call_ST_Function specifically to _avoid_
> the bounding box check. Just because we already know the inputs
> overlap, so we want to save some cycles.
I've done the same thing. What I found was an issue was not a few cycles
to compute the bounding box overlap, but that it allowed use of index
scans for geometries I knew intersected. I found this most common in
queries that generated geometries with geometry modifying functions. I
also ran into this in queries which joined against the same table
multiple times.
