[postgis-devel] regress/00-regress-install/lib/postgis-3.so: undefined symbol: CallerFInfoFunctionCall2
Sandro Santilli strk at kbt.io
Wed Mar 13 08:50:20 PDT 2019
On Wed, Mar 13, 2019 at 04:34:34PM +0100, Raúl Marín Rodríguez wrote:
> > I verified this was the problem and committed a change that will
> > fail earlier in this case and give a nice error for user, like this:
> I left a comment in the ticket maillist but I don't know who receives that.
> Your change is going to break https://trac.osgeo.org/postgis/ticket/4296.
> Can you use server_version_num instead of a regex?
The regex was copied verbatim from the _postgis_pgsql_version
function, which is the one used by `postgis_full_version` to report
mismatch between target PostgreSQL and running PostgreSQL version.
I'm ok if we want to change/simplify it but it would need to be done
consistently.
--strk;
