[postgis-devel] Error on make check
Bruce Rindahl bruce.rindahl at gmail.com
Wed Mar 13 20:29:23 PDT 2019
The error was:
psql:/home/pi/postgis-3.0.0dev/regress/00-regress-install/share/contrib/postgis/postgis.sql:6490:
ERROR:  function _st_distance(geography, geography, numeric, boolean) does
not exist
LINE 3:  AS 'SELECT $1 OPERATOR(&&) $2 AND _ST_Distance($1, $2, 0.0,...
HINT:  No function matches the given name and argument types. You might
need to add explicit type casts.
On Wed, Mar 13, 2019, 6:36 AM Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
> Don't know if i still have this.  Sorry - didn't notice the reference to
> the log file.  Everything is working fine now.  Let me see if I still have
> a machine on revision 17301.
> On Wed, Mar 13, 2019, 2:44 AM Sandro Santilli <strk at kbt.io> wrote:
>> On Thu, Mar 07, 2019 at 07:14:23PM -0800, Bruce Rindahl wrote:
>> > On revision 17301.
>> > Running make check gave this error at the end:
>> > Loading PostGIS into 'postgis_reg'
>> >  failed (Error encountered loading
>> > /tmp/pgis_reg/regress_log)
>> Did you take a look at /tmp/pgis_reg/regress_log ?
>> Is it the 'undefined symbol: CallerFInfoFunctionCall2' error I
>> reported in a new thread ?
>> --strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190313/3f9febac/attachment.html>
