[postgis-devel] Error on make check
Bruce Rindahl
bruce.rindahl at gmail.com
Fri Mar 15 19:22:29 PDT 2019
Running with revision 17343 gives no errors.
Thanks
On Thu, Mar 14, 2019, 7:49 AM Bruce Rindahl <bruce.rindahl at gmail.com> wrote:
> I ran against the current version this morning, but ran into several
> unrelated errors. I didn't have time to document them this morning -
> hopefully tonight.
> Thanks
> On Thu, Mar 14, 2019 at 4:19 AM Sandro Santilli <strk at kbt.io> wrote:
>> On Wed, Mar 13, 2019 at 08:29:23PM -0700, Bruce Rindahl wrote:
>> > The error was:
>> psql:/home/pi/postgis-3.0.0dev/regress/00-regress-install/share/contrib/postgis/postgis.sql:6490:
>> > ERROR: function _st_distance(geography, geography, numeric, boolean)
>> does
>> > not exist
>> > LINE 3: AS 'SELECT $1 OPERATOR(&&) $2 AND _ST_Distance($1, $2, 0.0,...
>> > HINT: No function matches the given name and argument types. You might
>> > need to add explicit type casts.
>> I think it was fixed more recently, do you confirm ?
>> If not, please file a ticket. --strk;
>> > On Wed, Mar 13, 2019, 6:36 AM Bruce Rindahl <bruce.rindahl at gmail.com>
>> wrote:
>> > > Don't know if i still have this. Sorry - didn't notice the reference
>> to
>> > > the log file. Everything is working fine now. Let me see if I still
>> have
>> > > a machine on revision 17301.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190315/108fb9e2/attachment.html>
