[postgis-devel] Docker and Lightweight Libraries
Adam Dadvar adam.dadvar at gmail.com
Fri May 10 04:37:51 PDT 2019
*"We build images for CI  where we build all the dependencies but*
*postgis
(https://cloud.docker.com/u/postgis/repository/docker/postgis/postgis-build-env
<https://cloud.docker.com/u/postgis/repository/docker/postgis/postgis-build-env>)but
not for distribution." *
Makes sense to use it for CI, again was mostly just wondering about
distribution, would be good to get people's thoughts on setting one up.
*"I'm not sure what bash scripts you are refering too, but this lookslike a
packaging request/issue."*
Sorry, I should have been more clear.
The bash script I'm referring to is *shp2pgsql, *I left it plural because I
wasn't sure if there are any other PostGIS commands that are executable
from the terminal.
This is more a packaging request yes. I'll admit I'm not sure on the
dependencies within PostGIS, so it may be that even just for
*shp2pgsql* requires
a lot of these dependencies, just wanted to float the idea and if we can
foresee a large amount of disk savings then maybe it is worth the effort.
*"One note, the packages I build locallyincluding everything (binaries and
libraries with full debug symbols,update scripts...) take ~43MB so
something looks suspicious in your300MB library."*
The 300MB footprint I'm talking about is the fact that if I remove PostGIS
from my machine (Fedora 29 with postgreSQL client only) I get 360MB of
freed space:
$ dnf remove postgis
Transaction Summary
Remove  33 Packages
Freed space: 360 M
Is this ok [y/N]:
Obviously this is mostly from the other libraries, but I was just wondering
if there was any way that a smaller client-only version could be created.
Regards,
Adam
On Fri, 10 May 2019 at 11:56, Raúl Marín Rodríguez <rmrodriguez at carto.com>
wrote:
> Hi,
> > Have been playing around with Docker a lot recently and was wondering if
> there was any reason why there is no official PostGIS Docker repository
> that builds on the PostgreSQL image?
> postgis (
> but not for distribution.
> > While we're on the subject of Docker and containers, I thought I'd ask
> if there is any scope for a lightweight PostGIS library that only has the
> bash scripts in it? A sort of "postgis-client" type of thing, that allows
> you to interact with remote databases running PostGIS without having to
> install the entire 300MB library yourself.
> like a packaging request/issue. One note, the packages I build locally
> including everything (binaries and libraries with full debug symbols,
> update scripts...) take ~43MB so something looks suspicious in your
> 300MB library.
> Regards
> carto.com
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20190510/e3b144a2/attachment.html>
