[postgis-devel] gzip support for ST_AsMVT
Martin Davis mtnclimb at gmail.com
Sun Nov 3 09:55:55 PST 2019
Great to hear that ST_AsMVT is useful.
The other PostGIS capability that is useful for web spatial applications is
the (recently enhanced) ST_AsGeoJSON.  This should also be gzipped over the
wire.  So this suggests a modular gzip capability would be more useful.
If this isn't provided in Postgres in some way (now or in near term)
perhaps we should just add a ST_Gzip function to PostGIS.
Out of curiosity, what platform do you use for your external gzipping layer?
On Sun, Nov 3, 2019 at 8:29 AM nyurik <yuriastrakhan at gmail.com> wrote:
> The amazing ST_AsMVT() has two common usage patterns:  copy resulting MVTs
> to
> a tile cache (e.g. .mbtiles file or a materialized view), or serve MVT to
> the users (direct SQL->browser approach).  Both patterns still require one
> additional data processing step -- gziping.
> Thus, rather than having a horizontally scalable db plus a simple IO-bound
> SQL->Web or a SQL->store process, one has to add a relatively CPU-intensive
> gzipping layer.  This is especially relevant if I try to create a PG table
> with the pre-generated tiles - I must use an external data compression
> process to retrieve a tile, gzip it, and store it back, instead of running
> a
> single query for copying all tiles.  My cursory look at the tile sizes
> indicate gzipping shrinks MVTs 50% to 300%.
> Note that a similar CPU-intensive step - creating MD5 tile hashes for a
> more
> efficient storage - can be easily done with PG's `md5()` function, whereas
> `gzip()` doesn't appear to exist.
> I would like to propose two possible solutions:
> * Implement ST_AsMVT(..., compress) parameter - NULL=no compression,
> 0-9=compression level.
>    PROs:  adds just the required functionality to where it is needed (YAGNI
> principle), does not require ungzip yet (ST_AsMVT is a one way function
> without the corresponding MVT->Table method)
>    CONs: less generic (unusable for non-MVT usage)
> * Implement gzip() or ST_gzip()
>    PROs:  a more generic approach not tied to MVTs
>    CONs:  logically implies the need of ungzip(), requires PG community to
> agree this functionality is needed
> Thanks!
> Sent from: http://postgis.17.x6.nabble.com/PostGIS-Dev-f3570762.html
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20191103/657a662c/attachment.html>
