[postgis-devel] gzip support for ST_AsMVT
Yuri Astrakhan yuriastrakhan at gmail.com
Mon Nov 4 01:49:49 PST 2019
Paul, one (possibly newbie) question - I noticed you used `gzip(bytea)`,
and I read in [1] that text performs about 17% better (for read queries,
not sure about in-memory operations). Does it make sense to add gzip(text)
variant?   I concatenate ST_AsMVT() data with STRING_AGG, thus end up with
a TEXT, and wonder if there is a conversion cost.  Thanks!!
[1] http://engineering.pivotal.io/post/bytea_versus_text_in_postgresql/
On Mon, Nov 4, 2019 at 4:24 AM Yuri Astrakhan <yuriastrakhan at gmail.com>
wrote:
> Paul rulez!!!! Thank you!!! :)
> Experimentation ensues...
> On Sun, Nov 3, 2019 at 9:29 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Excuse me,
>> https://github.com/pramsey/pgsql-gzip
>> P
>> On Sun, Nov 3, 2019 at 6:24 PM Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>> > I could not find a gzip extension on the web, even though I swear one
>> > already exists.
>> > So, I wrote up one, it's quite a small piece of work, but hopefully it
>> serves.
>> > https://github.com/pramsey/psql-gzip
>> > ATB,
>> > P
>> > On Sun, Nov 3, 2019 at 11:57 AM Yuri Astrakhan <yuriastrakhan at gmail.com>
>> wrote:
>> > > OSM -> PostgreSQL is done by Imposm 3, which updates database tables
>> on the daily/hourly/minute basis. Every time it runs, it generates a list
>> of changed tiles.  I do not know what process they use for it -- from my
>> perspective, I simply get the list of updated tiles on zoom 14 as a file,
>> and I could use it to regenerate cached tiles or purge them from Varnish.
>> Perhaps Imposm maintainers could find a good use for that functionality?
>> > > [1] https://imposm.org/docs/imposm3/latest/tutorial.html#expire-tiles
>> > > On Sun, Nov 3, 2019 at 2:41 PM Martin Davis <mtnclimb at gmail.com>
>> wrote:
>> > >> Good background to know.  Quite a bit to grok there!
>> > >> One question: does any part of that toolchain regenerate tile cache
>> subsets depending on detection of feature change?  And if so, would it be
>> useful to have a DB function which can determine the set of tile ids that
>> need to be refreshed (i.e. by mapping a (set of or single) geometry (or
>> envelopes) into a set of tile ids?
>> > >> On Sun, Nov 3, 2019 at 11:00 AM Yuri Astrakhan <
>> yuriastrakhan at gmail.com> wrote:
>> > >>> Martin, I am working on improving OpenMapTiles tooling [1] - the
>> ultimate goal is to have tiles generated in real time from the up-to-date
>> OSM data, and serve them directly to user's browser via some caching layer
>> (i.e. Varnish). The tools already contain postserve - a simple python
>> server that queries for MVT tiles (no compression yet, but can be easily
>> added)
>> > >>> The other task is tile pre-generation using tilelive-copy (nodejs)
>> - I wrote a tilelive-pgquery plugin [2] that queries PG for the tile,
>> compresses it, and passes it on to tilelive-copy for storage.
>> > >>> [1] OpenMapTiles tools -
>> https://github.com/openmaptiles/openmaptiles-tools
>> > >>> [2] tilelive-pgquery -
>> https://www.npmjs.com/package/tilelive-pgquery
>> > >>> On Sun, Nov 3, 2019 at 12:55 PM Martin Davis <mtnclimb at gmail.com>
>> wrote:
>> > >>>> Great to hear that ST_AsMVT is useful.
>> > >>>> The other PostGIS capability that is useful for web spatial
>> applications is the (recently enhanced) ST_AsGeoJSON.  This should also be
>> gzipped over the wire.  So this suggests a modular gzip capability would be
>> more useful.
>> > >>>> If this isn't provided in Postgres in some way (now or in near
>> term) perhaps we should just add a ST_Gzip function to PostGIS.
>> > >>>> Out of curiosity, what platform do you use for your external
>> gzipping layer?
>> > >>>> On Sun, Nov 3, 2019 at 8:29 AM nyurik <yuriastrakhan at gmail.com>
>> wrote:
>> > >>>>> The amazing ST_AsMVT() has two common usage patterns:  copy
>> resulting MVTs to
>> > >>>>> a tile cache (e.g. .mbtiles file or a materialized view), or
>> serve MVT to
>> > >>>>> the users (direct SQL->browser approach).  Both patterns still
>> require one
>> > >>>>> additional data processing step -- gziping.
>> > >>>>> Thus, rather than having a horizontally scalable db plus a simple
>> IO-bound
>> > >>>>> SQL->Web or a SQL->store process, one has to add a relatively
>> CPU-intensive
>> > >>>>> gzipping layer.  This is especially relevant if I try to create a
>> PG table
>> > >>>>> with the pre-generated tiles - I must use an external data
>> compression
>> > >>>>> process to retrieve a tile, gzip it, and store it back, instead
>> of running a
>> > >>>>> single query for copying all tiles.  My cursory look at the tile
>> sizes
>> > >>>>> indicate gzipping shrinks MVTs 50% to 300%.
>> > >>>>> Note that a similar CPU-intensive step - creating MD5 tile hashes
>> for a more
>> > >>>>> efficient storage - can be easily done with PG's `md5()`
>> function, whereas
>> > >>>>> `gzip()` doesn't appear to exist.
>> > >>>>> I would like to propose two possible solutions:
>> > >>>>> * Implement ST_AsMVT(..., compress) parameter - NULL=no
>> compression,
>> > >>>>> 0-9=compression level.
>> > >>>>>    PROs:  adds just the required functionality to where it is
>> needed (YAGNI
>> > >>>>> principle), does not require ungzip yet (ST_AsMVT is a one way
>> function
>> > >>>>> without the corresponding MVT->Table method)
>> > >>>>>    CONs: less generic (unusable for non-MVT usage)
>> > >>>>> * Implement gzip() or ST_gzip()
>> > >>>>>    PROs:  a more generic approach not tied to MVTs
>> > >>>>>    CONs:  logically implies the need of ungzip(), requires PG
>> community to
>> > >>>>> agree this functionality is needed
>> > >>>>> Thanks!
>> > >>>>> Sent from:
>> http://postgis.17.x6.nabble.com/PostGIS-Dev-f3570762.html
>> > >>>>> _______________________________________________
>> > >>>>> postgis-devel mailing list
>> > >>>>> postgis-devel at lists.osgeo.org
>> > >>>>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20191104/a9a7b998/attachment.html>
