[postgis-devel] Question about EWKT and Dimension qualifiers
Manuel Jesús Morillo
mmorillo at carto.com
Fri Nov 8 04:00:20 PST 2019
Hi all!
First of all I would like to say this is my first email in the list since I
joined OSGeo some days ago so I am sorry if I miss something! :)
I would like starting to contribute to Postgis and I was taking a look to
the ticket #4561 <https://trac.osgeo.org/postgis/ticket/4561> when some
questions came to my mind.
At this moment the function ST_AsEwkt is missing the ZM for a 3-dimensional
measured geometry:
query: SELECT ST_AsEwkt(ST_GeomFromText('POINTZM(10 10 2 3)'));
expected: POINT ZM (10 10 2 3)
output: POINT(10 10 2 3)
However, the ST_AsText (WKT ISO) is working as expected:
query: SELECT ST_AsText(ST_GeomFromText('POINTZM(10 10 2 3)'));
output: POINT ZM (10 10 2 3)
So if we change "WKT_EXTENDED" to "WKT_EXTENDED | WKT_ISO" in LWGEOM_asEWKT
/ ST_AsEWKT then the SRID and ZM are kept:
query: SELECT ST_AsEwkt(ST_GeomFromEWKT('SRID=100;POINTZM(10 10 2 3)'));
expected: "SRID=100;POINT ZM (10 10 2 3)"
output: "SRID=100;POINT ZM (10 10 2 3)"
But we should change other tests tests which are failing with these
changes, e.g.:
CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(0 0 0 0)",WKT_EXTENDED),"POINT(0 0 0
0)")
we should change it to:
CU_ASSERT_STRING_EQUAL(cu_wkt("POINT(0 0 0 0)",WKT_EXTENDED),"POINT ZM (0 0
0 0)")
According to this doc
<https://github.com/postgis/postgis/blob/master/doc/ZMSgeoms.txt>
the ST_AsEwkt function should omit the Z qualifier but in my opinion it
should have the same behaviour than WKT ISO in those cases.
What do you think?
Best.
Software Engineer
+1 917 463 3232 | mmorillo at carto.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20191108/26b96f84/attachment.html>
