[postgis-devel] Postgis 3.1 minimum requirements update
Regina Obe lr at pcorp.us
Mon Nov 11 07:46:29 PST 2019
You made good points here so I wanna change my vote to
+1 for 9.5
+0.5 for GEOS 3.8
+1 for GDAL 2.1 and Proj 4.9 – these actually make a lot of sense – but as you said was too late in release cycle.
(but Darafei – you got to reput this one back out for vote) – can’t just piggy back on Raul’s passing comment :)
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Darafei "Kom?pa" Praliaskouski
Sent: Monday, November 11, 2019 10:16 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Cc: Raúl Marín Rodríguez <rmrodriguez at carto.com>
Subject: Re: [postgis-devel] Postgis 3.1 minimum requirements update
> Minimum PG version: 9.6 (was 9.5)
What's the gain of changing this, to offset the pain caused by people
using 9.5?
PostGIS 3.1 is going to be released around the time 9.5 will become End of Life.
> Recommended GEOS version: 3.8 (was 3.7)
'Recommended" in a vacuum is odd, because the standard approach is to
run the most recent release from a given project, eccept that after big
changes it is sensible to hold off 3-6 months.  And, releases that
withdraw APIs have a much longer time before they can be considered
generally recommended (e.g. proj).
Setting GEOS 3.8 as minimum (instead of "recommended") will let us lose a large amount of code that was shifted into it from liblwgeom, including but not limited to MakeValid, and guarantee that all the users get all the functionality including the Frechet distance.
It will also let us ship Coverage Union as a function without the "alas your distro maintainer built postgis without it" curse.
We will still have some variablility because of upcoming GEOS 3.9/4.0, but keeping it at manageable level is generally a good idea.
Previously I proposed to also bump GDAL to 2.1 and PROJ to 4.9 for PostGIS 3.0. This did not come through as it was rather late in previous cycle, but getting it (or a year in the future stricter) would be good. This also lets us remove some quirks.
https://github.com/Komzpa/postgis/tree/ticket-4455
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20191111/4c4d610f/attachment.html>
