[postgis-devel] Postgis 3.1 minimum requirements update
    Regina Obe
    lr at pcorp.us
    Mon Nov 11 12:26:18 PST 2019
You can always install legacy.sql ontop of extensions.  For the cases I need it (which is rare I do) that.
I think DBaaS systems I forget which one - perhaps it was heroku even packaged the legacy.sql as an extension to get around the power user issue.
I've been thinking we probably should do the same - just bite the bullet and have legacy.sql be packaged as an extension.
It is kind of annoying that I have to give extra instructions about how to upgrade it.
If it were an extension - then upgrading it would be part of the
SELECT postgis_extensions_upgrade();
Command
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Justin Pryzby
Sent: Monday, November 11, 2019 3:17 PM
To: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] Postgis 3.1 minimum requirements update
On Mon, Nov 11, 2019 at 07:54:57PM +0100, Christoph Berg wrote:
> Most of the support requests around PostGIS we get at the company
> revolve around users having trouble upgrading non-extension
> installations. Why is that still a thing?
Is it because of legacy.sql ?
I've (finally) added that to our TODO list here.
Justin
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
