[postgis-devel] Proposal: Adding buffer parameter to ST_TileEnvelope()
rmrodriguez at carto.com rmrodriguez at carto.com
Wed Nov 13 10:23:50 PST 2019
On Wed, Nov 13, 2019 at 4:17 PM Yuri Astrakhan <yuriastrakhan at gmail.com> wrote:
> My understanding is that for a complete tiles support one always has to deal with a common set of tile params --  z, x, y, extent, buffer, srid. Those define pretty much everything there is to define about most tiles I have seen. I agree that having two params rather than just one is less ideal, and I haven't seen anyone using non-4096 extent yet, but we already support it in make geom, so extent should be defaulted to 4096 for consistency. Buffer should default to 0 in makeTile, whereas in geometry existing 256 default seems reasonable.
CARTO uses a configurable extent for MVTs, for example CartoVL uses
2048 but you can pass whatever you want to the map configuration and
it'll deal with it nicely. We aren't using `ST_TileEnvelope` so I
haven't paid much attention to it for now, and use ST_Expand over the
tile bbox. The tricky thing is that the extra size added needs to
depend both on the resolution (zoom level) and the buffersize and I'm
not sure how to expose that without exposing too much about the
implementation. I guess that something like accepting a number N and
the function would expand the tile N * the tile resolution.
To cover this case, I think it'd be better to have a
`ST_TileResolution(z integer)` and you can do it yourself. Following
your example:
ST_Expand(ST_TileEnvelope(x,y,z), ST_TileResolution(z) / :extent * :buffer)
Right?
Raúl Marín Rodríguez
carto.com
