[postgis-devel] Proposal: Adding buffer parameter to ST_TileEnvelope()
Paul Ramsey
pramsey at cleverelephant.ca
Thu Nov 14 04:58:13 PST 2019
> On Nov 13, 2019, at 11:35 PM, Yuri Astrakhan <yuriastrakhan at gmail.com> wrote:
> Rough implementation PR - https://github.com/postgis/postgis/pull/514 <https://github.com/postgis/postgis/pull/514>
> I am having some issues with unit tests (too much magic in auto-generated code?), so a Postgis guru's help might be needed.
> One open concern: extending envelope beyond antimeredian. Is this possible? Would a bbox from the tile that overflows to the other side of antimeredian match any geometries? For example, given two points - one at -179, and the other is at +179 (longitude), would they be found with the bbox that goes from -200..-160 ?
In geometry they would not match, in geography they would.
P
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20191114/357ed95f/attachment.html>
