[postgis-devel] postgis traceback hyperlink
Justin Pryzby
pryzby at telsasoft.com
Tue Nov 26 12:35:37 PST 2019
While transitioning a customer's server, I got an error:
|b'Traceback (most recent call last):\n File "/home/telsasoft/server/maps/map.py", line 17, in <module>\n img = m.draw ()\n_mapscript.MapServerError: msDrawMap(): Image handling error. Failed to draw layer named \'lines\'.\nmsPOSTGISLayerParseData(): Query error. Error parsing POSTGIS data variable: You specified \'using SRID=#\' but didnt have any numbers!\n\nMore Help:\n\nError with POSTGIS data variable. You specified \'link_geo FROM (SELECT * FROM ONLY sites) AS foo using SRID=srid#\'.\nStandard ways of specifiying are : \n(1) \'geometry_column from geometry_table\' \n(2) \'geometry_column from (sub query) as foo using unique column name using SRID=srid#\' \n\nMake sure you put in the \'using unique column name\' and \'using SRID=#\' clauses in.\n\nFor more help, please see http://postgis.refractions.net/documentation/ \n\nMappostgis.c - version of Jan 23/2004.\n\n'
The URL seems to be outdated:
The latest version it has is:
http://postgis.net/docs/manual-2.0/
Justin
