[postgis-devel] Inconsistencies in text output
rmrodriguez at carto.com rmrodriguez at carto.com
Fri Apr 10 09:32:51 PDT 2020
PRs with the changes (there are also some changes in the cunit
structure to ease the diff showing):
- Enforcing that we output the amount of DECIMAL digits that the user
has requested as precision:
https://github.com/postgis/postgis/pull/554
- Consider the precision as number of TOTAL (integer + decimal)
digits: https://github.com/postgis/postgis/pull/555
The first one does exactly what's documented in the functions
themselves, that is if you request precision you get
1.111111100000000018 (before you got 1.1111111), but the diff is
really massive (2435
changes just in regress/). The second one is closer to the current
behaviour (35 changes in regress/).
In light of these tests, I propose changing the documentation to
declare the precision as the number of total digits (before and after
the point) and enforce that for all functions for 3.1+, i.e. this PR
(https://github.com/postgis/postgis/pull/555) plus documentation
changes.
On Fri, Apr 10, 2020 at 4:22 PM <rmrodriguez at carto.com> wrote:
> Also note that it would be possible to limit the number of digits
> (integer or decimal) instead, which could be preferable but that's a
> breaking change to all the extension functions (since they are
> requesting 15 decimal digits, not 15 total digits).
> On Fri, Apr 10, 2020 at 4:07 PM <rmrodriguez at carto.com> wrote:
> > Hi everyone,
> > Lately I've been trying to improve the performance of output functions
> > and one of the areas where I got a massive (5x) improvement was
> > anything that output text (ST_AsText, ST_AsGeoJSON and so on) but the
> > implementation that I introduced for 3.1 has multiple hacks to keep
> > the output almost exactly the same as it was for 3.0.
> > Although most output functions have a `maxdecimaldigits` parameter
> > that represents `maximum number of decimal digits after floating
> > point` there are multiple cases where this isn't respected. Some
> > examples:
> > Select ST_AsText(ST_MakePoint(123456789012.1234567890123, 0), 4);
> > POINT(123456789012.123459 0)
> > The number should have 4 digits, but has 6.
> > Select ST_AsText(ST_MakePoint(0, 92114.013999999996), 15);
> > POINT(0 92114.014)
> > Select ST_AsText(ST_MakePoint(0, 92114.013999999996), 20);
> > POINT(0 92114.013999999995576)
> > This number has a significant digit on the 12th decimal digits, but
> > it's not shown if you request 15 decimal digits. But it is shown if
> > you request 20 decimal digits.
> > On the other hand, it doesn't work with ST_AsGeoJSON because it's
> > limited internally:
> > Select ST_AsGeoJSON(ST_MakePoint(0, 92114.013999999996), 20);
> > {"type":"Point","coordinates":[0,92114.014]}
> > So I want to propose some changes to unify the behaviour of all
> > functions that output coordinates. They aren't big changes but the
> > output of multiple regression tests will change, thus 3.0 and 3.1
> > output will change in some cases too; but I think it's worth it as we
> > get rid of bugs and we uniformize the output of all functions.
> > The rules would be like this:
> > - For (absolute) values under FP_TOLERANCE, we keep returning '0'.
> > - For big numbers (absolute value bigger than 1E15), we keep the
> > current behaviour and maintain the decimal digits to 8 - length of the
> > decimal part (it's odd but I don't see the need to change it).
> > - For smaller numbers:
> >   - The integer part is always printed in full (no changes).
> >   - The decimal part is always printed up to precision digits
> > (removing trailing zeros).
> >   - The decimal digit precision is capped between 0 and 20. This is
> > more than enough to guarantee round trip (double -> text -> same
> > double) and it allows us to know the max size of a double (so we can
> > keep the static allocations) as sign + 15 integer digits + "." + 20
> > decimal digits + "NULL".
> > I'm going to draft a PR with the changes, but any comment is more than
> > welcome before I push a change like this.
> > Raúl Marín Rodríguez
> > carto.com
> carto.com
carto.com
