[postgis-devel] Inconsistencies in text output
Paul Ramsey
pramsey at cleverelephant.ca
Fri Apr 17 08:43:53 PDT 2020
It's not so much that I'm not worried, as that I feel like it's a wide enough change to be a little beyond my comprehension... I know we recently changed default JSON output precision to use fewer digits to save space on the wire. The idea being that the primary use case for JSON was read-only shipping to web clients. Would this change push the number of JSON digits in the default back up?
The example shows that it's possible that harmonizing all formats might be counter-productive to previously agreed optimizations that made sense on a use-case basis.
This is a change that alters the outputs from what was previously expected. Are there usages you can envision where the change might surprise/break the end user application? The fact that the new behaviour is better/more consistent will not make any existing user happier if their app breaks. Is it possible we'll end up with those cases?
P.
> On Apr 17, 2020, at 6:16 AM, rmrodriguez at carto.com wrote:
> Hi all,
> I wanted to mention 2 things:
> First, I'm slightly worried that nobody cares about this. It makes me
> think that nobody cares about having a correct output for text output
> functions.
> Second, fixing the functions to output the requested (15 in most
> cases) decimal digits breaks the regression tests of any dependent
> project in many places. Not only that, but I think that having 15
> being the default doesn't make any sense as we ourselves are using 12
> digits (#define FP_TOLERANCE 1e-12) for tolerance and, for the common
> CRSs, it's enough precision to pinpoint a hair in my head. So if we
> decide to go that route it should be accompanied by a change in the
> default precision to something that makes more sense (8?).
> Any comments? If not I'll go trust my gut as soon as I have a sane CI
> passing (right now there appears to be multiple differences depending
> on the OS).
> On Mon, Apr 13, 2020 at 12:05 PM <rmrodriguez at carto.com> wrote:
>>> - The current documentation and design intent is to provide the ability to specify Max DECIMAL Digits, so changing this would be a breaking change
>> It would be a breaking documentation change, but normally not a
>> behaviour breaking change. There are 100x more changes in behaviour
>> when complying with the documentation.
>>> - It is not useful to specify the Max TOTAL Digits, since without knowing the magnitude of the numbers this leads to unknown and possibly varying precision of output numbers
>> Well, we already have varying precision due to the use of floating
>> point. The nth decimal digit has more precision the closer to 0 you
>> are, so is and the higher the integer part, the less meaningful
>> decimal digits you have so it helps to remove digits that don't carry
>> information.
>>> +1 to correctly respecting the limit on Max DECIMAL Digits
>>> -2 to changing the semantics to Max TOTAL Digits
>> I'm fine going either way, I just want to make sure everyone
>> understands the decision before we commit to one. If I was starting
>> from scratch, I'd choose to return the shortest representation
>> maintaining round trip safety but that would be an even greater
>> breaking change.
>> I'm going to wait a few extra days to see if there are any more
>> comments before committing to a final solution.
>> Raúl Marín Rodríguez
>> carto.com
> carto.com
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
