[postgis-devel] Proposal for sensible number output semantics
Martin Davis
mtnclimb at gmail.com
Sun Apr 19 10:48:56 PDT 2020
Sounds good! I look forward to seeing the results.
Can you provide a set of examples (AKA unit tests)? Then we can all see
how it works.
On Sun, Apr 19, 2020 at 9:53 AM <rmrodriguez at carto.com> wrote:
> Ok, I see that the proposal is basically the same but I have a different
> way to describe it.
> I got confused partly because I don't make the distinction at 15 precision
> and I always return the sortest with up to N decimal digits of precision,
> so 15 is not special but 17 will be the max digits in any case.
> By modifying ryu, I have implemented a method that returns the shortest
> decimal representation for our use case (<1e15) although it needs some
> optimization (adapting the ones already in ryu to print the integer parts).
> The thing is currently missing is the "truncate precision" as the one
> present in ryu is for all digits, so I might need to add a second one to
> round only the decimal digits to the desired precision.
> If nothing unexpectes happens I hope I'll have a fulk implementation soon
> so we can review the output diffences with the 3.0 output and confirms
> that's the behaviour thst we want. I would rather not write a RFC until we
> have something we are happy with that can be applied to all text output
> functions.
> On Saturday, April 18, 2020, Martin Davis <mtnclimb at gmail.com> wrote:
>> On Sat, Apr 18, 2020 at 12:22 PM <rmrodriguez at carto.com> wrote:
>>> On Sat, Apr 18, 2020 at 6:18 PM Martin Davis <mtnclimb at gmail.com> wrote:
>>> > When you say "limit" do you mean truncate or round? I don't think
>>> truncation is a good approach (based on what every other precision-limiting
>>> system I have seen does).
>>> > If you mean round then I *think* your suggestion is essentially the
>>> same as mine.
>>> Ideally, rounding.
>> Ah, that's good.
>>> > I would say precision 0..8 is most useful; beyond that not as much.
>>> > But surely there has to be some transition point at which rounding
>>> stops and "full" precision is used?
>>> Yes, but rounding might stop at different points
>> My idea is that 15 decimal digits is about the limit of DP precision.
>> Below that rounding would be noticeable, beyond it it would not be. It
>> could be 14 or 13 instead, I think. The key point is that the current
>> default will produce full precision.
>> >> - There is no artificial distinction between < 15 and > 15, which
>>> >> eliminates inconsistencies. Note that in your proposal you would get
>>> >> odd things like this:
>>> >> - 0.300000011920928955078125 with precision 10 -> 0.3000000119
>>> >> - 0.300000011920928955078125 with precision 20 -> 0.3 (since 0.3 has
>>> >> the same double representation)
>>> > I don't see how 0.300000011920928955078125 has the same DP
>>> representation as 0.3. DP has about 16 digits of precision, so surely the
>>> first number would be represented as (close to) 0.300000011920929 ?
>>> Sorry, I took a 32bit float example (from tryu) so it doesn't work
>>> with 64bits. Let's see a 64 bit double example:
>>> postgis=# Select ST_AsText(ST_MakePoint(0,
>>> 0.299999999999999988897769753748), 30);
>>> st_astext
>>> POINT(0 0.299999999999999988897769753748)
>>> (1 row)
>>> postgis=# Select ST_AsText(ST_MakePoint(0, 0.3), 30);
>>> st_astext
>>> (1 row)
>> Okay, that makes more sense.
>>> In both those examples, for anything except precision 0, IMO the
>>> output should be POINT(0 0.3). Why? Because both
>>> 0.29999999999999998889776975374 and 0.3 have the same double
>>> representation (in hex 0x3fd3333333333333) so when you import 0.3 you
>>> are getting the same value, thus it makes sense to output the shortest
>>> representation in all cases.
>> Yes, and I think that will happen with the proposed scheme?
>>> From what I understood of your proposal, there would be a precision
>>> (17+) where you would get more digits beyond 0.3. In my proposal you
>>> would never get any more digits.
>> No, at 15 and above requested digits you would get "full precision" and
>> no more.
>> The intent is NOT to allow the user to force a meaningless precision to
>> be output. There are two goals:
>> a) allow output of numbers with a textual precision that matches the
>> known DP precision. For instance, if ST_SnapToGrid(geom, .01) is used then
>> output should only show 2 decimal digits (even if roundoff actually causes
>> a bit of drift in the internal representation.
>> b) allow output of full (round-trippable) precision, with that as the
>> default
>> Part of the motivation for (a) is that I hoping that "soon" PostGIS will
>> gain the ability to execute some operations to a specified precision (in
>> particular overlay, and also a better geometry rounding capability) . This
>> will make moving data in out of PostGIS more robust, since it will prevent
>> creating geometry in PostGIS that carries excess precision and then becomes
>> invalid when exported at a lower precision.
>> Ideally we should capture all this as an RFC, and then (if implemented)
>> document it in the manual (with examples).
> Raúl Marín Rodríguez
> carto.com
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200419/7177e9d5/attachment.html>
