[postgis-devel] Function Removal
Paul Ramsey
pramsey at cleverelephant.ca
Wed Dec 16 11:41:47 PST 2020
I feel like we've been over this before, but I ran into it again and I'm wondering what we think our best practice should be.
The issue is the removal of stacked multi-parameter functions. We have:
CREATE FUNCTION ST_MakePoint(float8, float8)
CREATE FUNCTION ST_MakePoint(float8, float8, float8)
CREATE FUNCTION ST_MakePoint(float8, float8, float8, float8)
What's missing here? A place to set the SRID! So we constantly have this formation:
ST_SetSRID(ST_MakePoint(...), ...)
Which is, let's face it, ugly. So being a smart boy I thought:
CREATE FUNCTION ST_MakePoint(x float8, y float8, z float8 default null, m float8 default null, srid integer default null)
And then I updated the underlying C function to handle the nulls, and it works wonderfully:
postgis=# select st_asewkt(ST_MakePoint(1, 2, srid => 123));
SRID=123;POINT(1 2)
Except, unfortunately now the old form is broken.
postgis=# select st_asewkt(ST_MakePoint(1.2, 2.33));
ERROR: function st_makepoint(double precision, double precision) is not unique
HINT: Could not choose a best candidate function. You might need to add explicit type casts.
Yeah, it could be either my new one or the two-parameter form of the old one.
The obvious fix would be to remove the old signatures at the same time as adding the new one, but as I recall this leads to upgrade issues? This is where my memory is failing. I know (a) a single signature with defaults and argument names is nicer and cleaner and also (b) every time I've done it there's been some kind of an outcry / mess.
Any help, thoughts?
P
