[postgis-devel] Function Removal
Sandro Santilli
strk at kbt.io
Wed Dec 16 13:42:04 PST 2020
On Wed, Dec 16, 2020 at 04:22:48PM -0500, Regina Obe wrote:
> Add SRID to ST_Point(x,y) -- you can keep existing or overload. Overloading
> with another that has srid not optional would be more backward compatible.
> That's the one I use and that most people should be using as it's shorter to
> type and name wise is listed in SQL/MM.
I belive SQL/MM knows about Z as well
Better be strict on SQL/MM definitions when touching those
signatures.
--strk;
