[postgis-devel] Function Removal
Paul Ramsey pramsey at cleverelephant.ca
Wed Dec 16 15:39:46 PST 2020
https://github.com/postgis/postgis/pull/594
> On Dec 16, 2020, at 3:35 PM, Martin Davis <mtnclimb at gmail.com> wrote:
> Whoa...  how does it disambiguate?  Seems like fertile ground for bugs.
> On Wed, Dec 16, 2020 at 3:19 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> SQL/MM believes in having All The Variants.
> CREATE CONSTRUCTOR METHOD ST_Point (awkb BINARY LARGE OBJECT(ST_MaxGeometryAsBinary)) RETURNS ST_Point
> CREATE CONSTRUCTOR METHOD ST_Point (awkb BINARY LARGE OBJECT(ST_MaxGeometryAsBinary), ansrid INTEGER) RETURNS ST_Point
> CREATE CONSTRUCTOR METHOD ST_Point (xcoord DOUBLE PRECISION, ycoord DOUBLE PRECISION) RETURNS ST_Point
> CREATE CONSTRUCTOR METHOD ST_Point (xcoord DOUBLE PRECISION, ycoord DOUBLE PRECISION, ansrid INTEGER) RETURNS ST_Point
> CREATE CONSTRUCTOR METHOD ST_Point (xcoord DOUBLE PRECISION, ycoord DOUBLE PRECISION, zcoord DOUBLE PRECISION) RETURNS ST_Point
> CREATE CONSTRUCTOR METHOD ST_Point (xcoord DOUBLE PRECISION, ycoord DOUBLE PRECISION, zcoord DOUBLE PRECISION, ansrid INTEGER) RETURNS ST_Point FOR ST_Point BEGIN
> CREATE CONSTRUCTOR METHOD ST_Point (xcoord DOUBLE PRECISION, ycoord DOUBLE PRECISION, zcoord DOUBLE PRECISION, mcoord DOUBLE PRECISION) RETURNS ST_Point
> CREATE CONSTRUCTOR METHOD ST_Point (xcoord DOUBLE PRECISION, ycoord DOUBLE PRECISION, zcoord DOUBLE PRECISION, mcoord DOUBLE PRECISION, ansrid INTEGER) RETURNS ST_Point
> > On Dec 16, 2020, at 1:42 PM, Sandro Santilli <strk at kbt.io> wrote:
> > On Wed, Dec 16, 2020 at 04:22:48PM -0500, Regina Obe wrote:
> >> Add SRID to ST_Point(x,y) -- you can keep existing or overload.  Overloading
> >> with another that has srid not optional would be more backward compatible.
> >> That's the one I use and that most people should be using as it's shorter to
> >> type and name wise is listed in SQL/MM.
> > I belive SQL/MM knows about Z as well
> > Better be strict on SQL/MM definitions when touching those
> > signatures.
> > --strk;
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
