[postgis-devel] Function Removal
Bruce Rindahl bruce.rindahl at gmail.com
Thu Dec 17 14:27:03 PST 2020
I agree with all that but it could have advantages:
ST_Translate(geom,x=>10) for a shift to the right,
ST_Translate(geom,y=>10) for a shift up, ST_Scale(z=>10) for vertical
distortion.
  The functions , comments, and documents would all have to be updated and
in sync with 'accepted' names.
On Thu, Dec 17, 2020 at 2:19 PM Regina Obe <lr at pcorp.us> wrote:
> > Since they've come in we've really under-used named parameters. Some of
> > that because of legacy, some of it because of mental inertia. But for
> these
> > kinds of things they seem pretty ideal to me. Mean what you say, say what
> > you mean, have what your parameters mean be clear instead of opaque. A
> > good habit, all in all.
> > P
> In the beginning I thought named args were great, but I've come to think of
> them as being a little evil.
> Don't get me wrong -- they are indispensable in raster and pgRouting, cause
> there is a butt load of arguments and it's hard to undo or even
> questionable
> if we should.
> But for cases where we have few args, I find the evilness much worse than
> the disease they are there to cure.
> Mostly because of our indecision with coming up with good names and then
> changing our mind
> and then the fact our names in the docs don't even always match the named
> args ones we have .
> Remember Paul when your OCD kicked in and you decided to rename an arg?
> Oops we can't change the name of the arg without dropping the function oops
> we can't rename it because what if someone is using the name.
> So I don't care what the OGC says
> ST_Point(x,y, srid)
> With last arg always meaning srid seems clearest to me.
> No overloading with z,m etc.
> Have separate named functions for that.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201217/c26635bf/attachment.html>
