[postgis-devel] PSC Vote: Add Phillip Ross to PostGIS Docker Hub org
Yuri Astrakhan yuriastrakhan at gmail.com
Tue Feb 4 10:51:49 PST 2020
See the section "Creating new Repositories" and the sections after that --
I think we should actually push to move the existing postgis docker there,
rather than host it as part of postgis repo -- a wider docker-aware
community will be involved rather than purely postgis community.
https://github.com/docker-library/official-images
On Tue, Feb 4, 2020 at 1:47 PM Regina Obe <lr at pcorp.us> wrote:
> Didn’t even know there was such a thing.  What’s involved to be sanctioned
> as an official image?  If not too much work I’d say we should go for it.
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Yuri Astrakhan
> *Sent:* Tuesday, February 4, 2020 1:32 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> *Subject:* Re: [postgis-devel] PSC Vote: Add Phillip Ross to PostGIS
> Docker Hub org
> P.S. This also raises a question -- can Postgis be published via the
> official channel as well -- this way it can be used without a prefix, i.e.
>  "docker run postgis"  instead of   "docker run postgis/postgis"
> https://github.com/docker-library/postgres is the postgres repository.
> On Tue, Feb 4, 2020 at 1:29 PM Yuri Astrakhan <yuriastrakhan at gmail.com>
> wrote:
> On Tue, Feb 4, 2020 at 12:44 PM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> Is there an “official postgres image” we layer on, or is this something
> else? Does it layer on a particular linux image?
>  It relies on two "official" (Docker-community maintained) docker images -
> postgres:<version> and postgres-alpine:<version> -- see
> https://hub.docker.com/_/postgres .  The non-alpine
> uses debian:stretch-slim as the base image.
> The dockerfile example references:
> https://github.com/appropriate/docker-postgis/blob/master/11-2.5/Dockerfile#L1
> https://github.com/appropriate/docker-postgis/blob/master/11-2.5/alpine/Dockerfile#L1
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200204/56370022/attachment.html>
