[postgis-devel] PostGIS 3.0.1 released
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Sat Feb 22 14:05:37 PST 2020
The PostGIS Team is pleased to release PostGIS 3.0.1.
Best served with PostgreSQL 12.2, GEOS 3.8.0, SFCGAL 1.3.7, GDAL
3.0.4, PROJ 6.3.1, protobuf-c 1.3.3, json-c 0.13.1.
source download https://download.osgeo.org/postgis/source/postgis-3.0.1.tar.gz
NEWS https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.1/NEWS
PDF docs en https://download.osgeo.org/postgis/docs/postgis-3.0.1.pdf
This is the first stable release of PostGIS done after our move to Git
and that supports PostgreSQL 13 development release.
Details of this release can be found in NEWS file:
https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.0.1/NEWS which
is also included in source tar ball and in this email.
If you come across any issues, feel free to report via our ticket
tracker https://trac.osgeo.org/postgis or mailing list with details as
described here - https://postgis.net/support/. For security issues,
send reports to security at postgis.net.
Breaking Changes
#4637 svn number replaced by git hash in version output (Sandro
Santilli, Regina Obe, Bas Couwenberg)
New Features
#4617, Add configure switch --without-phony-revision (Raúl Marín)
Use to prevent postgis_revision.h from rebuilding (when building from
tar ball) and building in a gitted folder.
Bug Fixes and Enchantments
#4558, Fix oversimplification of polygon inner rings (Raúl Marín)
#4588, Fix update when ST_Union(geometry) doesn’t exist (Raúl Marín)
#4590, Fix pgupgrade issue with STLineCrossingDirection (Raúl Marín)
#4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
#4600, Improve precision of ST_TileEnvelope (Raúl Marín)
#4605, Fix postgis_upgrade.pl with PostgreSQL 12 (Matti Linnanvuori)
#4606, Respect user’s LDFLAGS in postgis module build (Sandro Santilli)
#4610, Add in logic to install postgistigergeocoder from unpackaged (Regina Obe)
#4581, Installing postgis_raster from unpackaged tries to use wrong
schema (Regina Obe)
#4596, The script to generate nationscriptload.sh is missing a
trailing quote (Bill Mill)
#4608, PG12: Fix several bugs in the index support function (Raúl Marín)
#4621, Prevent stack overflow when parsing WKB (Raúl Marín)
#4626, Support pkg-config for libxml2 (Bas Couwenberg)
#4632, Allow building with PostgreSQL 13 (Raúl Marín)
#4570, Include raster2pgsql in windows packaging (Regina Obe)
