[postgis-devel] About EXTENSION from UNPACKAGED on PostgreSQL 13
Bruce Rindahl
bruce.rindahl at gmail.com
Wed Feb 26 13:12:37 PST 2020
When ever I upgrade, I simply install the new version side by side on the
same machine but on a different port. Then I do:
pg_restore -p 5432 mydbase | psql -p 5433 mydbase
and see if anything throws an error. If everything works, I test it for a
while and then finally shut them down and swap ports in postgresql.conf
Will this avoid the issue?
On Wed, Feb 26, 2020 at 12:11 PM Regina Obe <lr at pcorp.us> wrote:
> > Presumably 15 years out from the 1.x -> 2.x we can stop worrying about
> > bundling unpackaged postgis into an extension, and just recommend a hard
> > upgrade dump/restore to the hardy souls still running 1.x.
> > P.
> We don't need to worry about 1.x cause 1.x can only do a hard upgrade to 2
> or 3. We never supported soft upgrade from 1.x
> Easy solution there is just to install postgis extension and do
> pg_restore/postgis_restore of your data.
> So it's really just the 2.1 -> 3 that are of concern.
> I think now is a fine time to encourage everyone to upgrade to 3 if they
> can so they don't need to suffer any crazy solutions we come up with :)
> Turn this into a convenient emergency.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200226/11bf6e9b/attachment.html>
