[postgis-devel] About EXTENSION from UNPACKAGED on PostgreSQL 13
Sandro Santilli
strk at kbt.io
Thu Feb 27 09:51:30 PST 2020
On Thu, Feb 27, 2020 at 12:33:52PM -0500, Stephen Frost wrote:
> > Can you give an example attack vector ?
> It's really not hard to imagine.. If an existing object is owned by a
> non-superuser and you put it into a package, and then use that object in
> some way during the extension script (which is running as a superuser..)
> then someone could gain superuser access.
Ok, this is something we can fix. Worth a ticket, in the road to
become a trusted extension. But we can fix (we can check ownership of
objects before packaging them).
> There are also issues if you
> end up with functions in untrusted languages that are owned by
> non-superusers.
Same fix: we can check ownership before packaging.
> Considering the PG folks have, quite resonably, decided that it's not
> trivial to "plug those holes" and aren't planning to provide any support
> for doing so, I seriously, seriously, doubt that you would be able to
> somehow as an extension.
Dubts are of no help. An exact case scenario showing an impossible
to fix hole would. Can you provide that ? I do have some thoughts
about search paths and friends but not a definitive attack vector
(we CREATE OR REPLACE functions anyway).
> I strongly feel that this is a seriously bad idea. Unpackaged installs
> really shouldn't exist these days and trying to hack around things to
> make it safe to turn some random jumble of functions into an extension
> is just a really bad idea.
I guess we can avoid the randomness.
> Properly install the extension and then migrate to it.
This would mean forcing a dump/reload, right ?
--strk;
