[postgis-devel] WKT format of MULTIPOINT
Andy Teucher
andy.teucher at gmail.com
Wed Jan 15 08:37:37 PST 2020
Thanks very much for this Martin, and thanks for pointing out that it’s likely geoserver that’s the culprit here…
Is there appetite to consider this change? If backward compatibility is desirable, I suppose another option could be a new argument in st_astext(), where the default uses the current behaviour? I could open a ticket if you’d like…
Thanks again,
Andy
Date: Sat, 28 Dec 2019 15:28:30 -0800
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] WKT format of MULTIPOINT
Message-ID:
<CAK2ens1wHtav8ZWJGaOYrTWWZJZjS7h0DRGP2RTghY=Rbgd3ww at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
This doesn't change the question, but I'm 99% sure that it is Geoserver
which is refusing to parse the paren-free MultiPoint, not Oracle.
This *may* affect the discussion, however, since that's at least two major
products which do not accept the "incorrect" syntax.
On Wed, Dec 18, 2019, 12:23 PM Andy Teucher <andy.teucher at gmail.com> wrote:
> The WKT representation of MULTIPOINT features can take two different
> forms, both of which are accepted (almost) universally. PostGIS (st_astext)
> implements the format without parentheses around individual point
> coordinate pairs:
> MULTIPOINT (0 0, 1 1)
> vs
> MULTIPOINT ((0 0), (1 1))
> I know this has been discussed in the past (
> https://lists.osgeo.org/pipermail/postgis-devel/2013-December/023990.html
> and https://trac.osgeo.org/postgis/ticket/2558) however I’ve come across
> a situation where it is making a difference.
> I have been using a geoserver wfs service to obtain spatial data, and
> supplying multipoint features to a geometry predicate (e.g., INTERSECTS)
> without nested parenthesis fails:
> $ wget -O "a.json" "
> https://openmaps.gov.bc.ca/geo/pub/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&outputFormat=application/json&typeNames=WHSE_BASEMAPPING.GBA_LOCAL_REG_GREENSPACES_SP&SRSNAME=EPSG:3005&CQL_FILTER=INTERSECTS(SHAPE,
> MULTIPOINT (1236285 463726.8, 1228264 463547.4))"
> --2019-12-18 12:08:52--
> https://openmaps.gov.bc.ca/geo/pub/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&outputFormat=application/json&typeNames=WHSE_BASEMAPPING.GBA_LOCAL_REG_GREENSPACES_SP&SRSNAME=EPSG:3005&CQL_FILTER=INTERSECTS(SHAPE,%20MULTIPOINT%20(1236285%20463726.8,%201228264%20463547.4))
> Resolving openmaps.gov.bc.ca (openmaps.gov.bc.ca)... 142.34.140.41
> Connecting to openmaps.gov.bc.ca (openmaps.gov.bc.ca)|142.34.140.41|:443...
> connected.
> HTTP request sent, awaiting response... 400
> 2019-12-18 12:08:52 ERROR 400: (no description).
> But it works when inner parentheses are present:
> MULTIPOINT ((1236285 463726.8), (1228264 463547.4)))"
> --2019-12-18 12:10:20--
> https://openmaps.gov.bc.ca/geo/pub/wfs?SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&outputFormat=application/json&typeNames=WHSE_BASEMAPPING.GBA_LOCAL_REG_GREENSPACES_SP&SRSNAME=EPSG:3005&CQL_FILTER=INTERSECTS(SHAPE,%20MULTIPOINT%20((1236285%20463726.8),%20(1228264%20463547.4)))
> connected.
> HTTP request sent, awaiting response... 200
> Length: unspecified [application/json]
> Saving to: ‘a.json’
> a.json [ <=> ] 3.59K --.-KB/s in 0s
> 2019-12-18 12:10:20 (35.4 MB/s) - ‘a.json’ saved [3678]
> I believe the database behind the geoserver is Oracle, which I have seen
> elsewhere only accepts the variety of MULTIPOINT with nested parentheses (
> https://viswaug.wordpress.com/2011/02/13/well-known-text-wkt-representation-for-multipoint/
> What is the possibility of PostGIS being able to output the nested-parens
> version of MULTIPOINT wkt?
> Thanks for your time!
> Andy Teucher
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
