[postgis-devel] Failed assert in rt_raster_from_band
Jaime Casanova
jaime.casanova at 2ndquadrant.com
Thu Jun 4 00:34:54 PDT 2020
Hi everyone,
i was running sqlsmith on postgresql with postgis enabled and got
failed assertion very quickly.
postgres version
PostgreSQL 12.3 (Debian 12.3-1.pgdg100+1) on x86_64-pc-linux-gnu,
compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
postgis full version
POSTGIS="2.5.4" [EXTENSION] PGSQL="120" GEOS="3.7.1-CAPI-1.11.1
27a5e771" PROJ="Rel. 5.2.0, September 15th, 2018" GDAL="GDAL 2.4.0,
released 2018/12/14" LIBXML="2.9.4" LIBJSON="0.12.1"
LIBPROTOBUF="1.3.1" RASTER
btw, i was running this on a debian 10 machine
attached are:
- a script to create a single postgis enabled table with some data
- the query that crashes
- gdb "bt full" output
Anything else I can do to help debug this?
Jaime Casanova www.2ndQuadrant.com
PostgreSQL Development, 24x7 Support, Remote DBA, Training & Services
#0 __GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
set = {__val = {0, 94583955378400, 0, 140496725435607, 94587992244224, 94583955378400, 94583955378501, 94583955378400, 94583955378400, 94583955378512, 94583955378700,
94583955378400, 94583955378700, 0, 0, 0}}
pid = <optimized out>
tid = <optimized out>
ret = <optimized out>
#1 0x00007fc7f1640535 in __GI_abort () at abort.c:79
save_stage = 1
act = {__sigaction_handler = {sa_handler = 0x56060b144ea0, sa_sigaction = 0x56060b144ea0}, sa_mask = {__val = {0, 303, 94583955378400, 0, 0, 0, 21474836480,
140730199141784, 140730199141632, 140496679386162, 140496679386162, 0, 17693867717872550656, 140496726520762, 0, 140496679386162}}, sa_flags = -441859500,
sa_restorer = 0x7fc7e5a97507}
sigs = {__val = {32, 0 <repeats 15 times>}}
#2 0x00007fc7f164040f in __assert_fail_base (fmt=0x7fc7eeaabc32 <error: Cannot access memory at address 0x7fc7eeaabc32>, assertion=0x7fc7e5a97507 "NULL != raster",
file=0x7fc7e5a9c254 "rt_raster.c", line=1443, function=<optimized out>) at assert.c:92
str = 0x56060b144ea0 "@\351\r\v\006V"
total = 4096
#3 0x00007fc7f164e102 in __GI___assert_fail (assertion=assertion at entry=0x7fc7e5a97507 "NULL != raster", file=file at entry=0x7fc7e5a9c254 "rt_raster.c", line=line at entry=1443,
function=function at entry=0x7fc7e5a9c520 <__PRETTY_FUNCTION__.44880> "rt_raster_from_band") at assert.c:101
No locals.
#4 0x00007fc7e5a840e5 in rt_raster_from_band (raster=<optimized out>, bandNums=bandNums at entry=0x7ffe4d876f24, count=count at entry=1) at rt_raster.c:1443
rast = 0x0
i = 0
j = 0
idx = <optimized out>
flag = <optimized out>
gt = {0, 0, 0, 0, 0, 0}
__PRETTY_FUNCTION__ = "rt_raster_from_band"
#5 0x00007fc7e5a53d90 in RASTER_union_finalfn (fcinfo=0x7ffe4d876f80) at rtpg_mapalgebra.c:2905
bandNums = {0}
iwr = 0x56060b182dc0
_rtn = 0x0
_raster = 0x0
pgraster = 0x0
i = 0
j = <optimized out>
itrset = 0x56060b17eda0
_band = <optimized out>
noerr = 1
status = <optimized out>
pixtype = <optimized out>
hasnodata = <optimized out>
nodataval = 0
__func__ = "RASTER_union_finalfn"
#6 0x000056060a3b8881 in finalize_windowaggregate (winstate=winstate at entry=0x56060b16efa0, peraggstate=peraggstate at entry=0x56060b1884b0, result=result at entry=0x56060b188cc8,
isnull=isnull at entry=0x56060b189218, perfuncstate=<optimized out>) at ./build/../src/backend/executor/nodeWindowAgg.c:625
anynull = <optimized out>
i = <optimized out>
fcinfodata = {fcinfo = {flinfo = 0x56060b188520, context = 0x56060b16efa0, resultinfo = 0x0, fncollation = 0, isnull = false, nargs = 1, args = 0x7ffe4d876fa0},
fcinfo_data = " \205\030\v\006V\000\000\240\357\026\v\006V", '\000' <repeats 16 times>, "\001\000\300-\030\v\006V", '\000' <repeats 18 times>, "\001\000\000\000q\000\000\000\211\002", '\000' <repeats 14 times>, "q", '\000' <repeats 15 times>, " p\207M\376\177\000\000\n\244K\n\006V\000\000\220p\207M\376\177\000\000\000\371\n\346\307\177\000\000\001\000\000\000\000\000\000\000\220\363\004\v\006V\000\000\000\366\270\345\307\177", '\000' <repeats 11 times>, "q\207M\376\177\000\000b\312K\n\006V\000\000\a", '\000' <repeats 11 times>, "p\000\000\000\067q\207M\376\177\000\000"...}
fcinfo = 0x7ffe4d876f80
numFinalArgs = <optimized out>
oldContext = 0x56060b16ec50
#7 0x000056060a3bbbcd in eval_windowaggregates (winstate=0x56060b16efa0) at ./build/../src/backend/executor/nodeWindowAgg.c:992
result = 0x56060b188cc8
isnull = 0x56060b189218
aggregatedupto_nonrestarted = <optimized out>
econtext = 0x56060b16f490
agg_row_slot = <optimized out>
peraggstate = 0x56060b1884b0
numaggs = 1
wfuncno = <optimized out>
numaggs_restart = <optimized out>
i = <optimized out>
oldContext = <optimized out>
agg_winobj = <optimized out>
temp_slot = <optimized out>
peraggstate = <optimized out>
numaggs = <optimized out>
i = <optimized out>
econtext = <optimized out>
__func__ = "eval_windowaggregates"
__errno_location = <optimized out>
ok = <optimized out>
result = <optimized out>
isnull = <optimized out>
#8 ExecWindowAgg (pstate=0x56060b16efa0) at ./build/../src/backend/executor/nodeWindowAgg.c:2206
winstate = 0x56060b16efa0
i = <optimized out>
numfuncs = <optimized out>
__func__ = "ExecWindowAgg"
#9 0x000056060a388ac3 in ExecProcNode (node=0x56060b16efa0) at ./build/../src/include/executor/executor.h:239
No locals.
#10 ExecutePlan (execute_once=<optimized out>, dest=0x56060b17d308, direction=<optimized out>, numberTuples=0, sendTuples=<optimized out>, operation=CMD_SELECT,
use_parallel_mode=<optimized out>, planstate=0x56060b16efa0, estate=0x56060b16ed60) at ./build/../src/backend/executor/execMain.c:1646
current_tuple_count = 0
current_tuple_count = <optimized out>
#11 standard_ExecutorRun (queryDesc=0x56060b0fffa0, direction=<optimized out>, count=0, execute_once=<optimized out>) at ./build/../src/backend/executor/execMain.c:364
estate = 0x56060b16ed60
operation = CMD_SELECT
dest = 0x56060b17d308
sendTuples = <optimized out>
oldcontext = 0x56060b0ffe90
__func__ = "standard_ExecutorRun"
#12 0x000056060a4ee6ec in PortalRunSelect (portal=portal at entry=0x56060b022850, forward=forward at entry=true, count=0, count at entry=9223372036854775807,
dest=dest at entry=0x56060b17d308) at ./build/../src/backend/tcop/pquery.c:929
queryDesc = 0x56060b0fffa0
direction = <optimized out>
nprocessed = <optimized out>
__func__ = "PortalRunSelect"
#13 0x000056060a4efc68 in PortalRun (portal=portal at entry=0x56060b022850, count=count at entry=9223372036854775807, isTopLevel=isTopLevel at entry=true,
run_once=run_once at entry=true, dest=dest at entry=0x56060b17d308, altdest=altdest at entry=0x56060b17d308, completionTag=0x7ffe4d877930 "")
at ./build/../src/backend/tcop/pquery.c:770
save_exception_stack = 0x7ffe4d877b40
save_context_stack = 0x0
local_sigjmp_buf = {{__jmpbuf = {1, 639202057418084750, 94583953888272, 140730199144752, 94583954483280, 94583955903240, 639202057273381262, 6570304842336211342},
__mask_was_saved = 0, __saved_mask = {__val = {2817148525, 0, 94583954494840, 94583954491632, 94583769792513, 94583955390096, 2, 140730199144750, 1, 112,
94583953881360, 2, 94583954483280, 140730199144624, 94583944138941, 2}}}}
saveTopTransactionResourceOwner = 0x56060afe8400
saveTopTransactionContext = 0x56060b060420
saveActivePortal = 0x0
saveResourceOwner = 0x56060afe8400
savePortalContext = 0x0
saveMemoryContext = 0x56060b060420
__func__ = "PortalRun"
#14 0x000056060a4ebabc in exec_simple_query (
query_string=0x56060af8fa20 "select \n public.st_union(\n cast(cast(null as raster) as raster),\n cast(sample_12.gid as int4)) over (partition by sample_12.hip2 order by sample_12.hip2) as c5 \n from \n public."...) at ./build/../src/backend/tcop/postgres.c:1215
parsetree = 0x56060af913e0
portal = 0x56060b022850
snapshot_set = <optimized out>
commandTag = <optimized out>
completionTag = "\000\000\000\000\002\000\000\000\t", '\000' <repeats 16 times>, "\203\213z\000\000\000\000Q\000\000\000\000\000\000\000\340z\207M\376\177\000\000 \372\370\n\006V\000\000\070h\376\n\006V\000"
querytree_list = <optimized out>
plantree_list = <optimized out>
receiver = 0x56060b17d308
format = 0
dest = DestRemote
oldcontext = 0x56060b060420
parsetree_list = 0x56060af91430
parsetree_item = 0x56060af91410
save_log_statement_stats = false
was_logged = false
use_implicit_block = false
msec_str = "\000\000\000\000\002\000\000\000\t", '\000' <repeats 16 times>, "\203\213z\000\000\000"
__func__ = "exec_simple_query"
#15 0x000056060a4ed4be in PostgresMain (argc=<optimized out>, argv=argv at entry=0x56060afe6990, dbname=<optimized out>, username=<optimized out>)
at ./build/../src/backend/tcop/postgres.c:4247
query_string = 0x56060af8fa20 "select \n public.st_union(\n cast(cast(null as raster) as raster),\n cast(sample_12.gid as int4)) over (partition by sample_12.hip2 order by sample_12.hip2) as c5 \n from \n public."...
firstchar = <optimized out>
input_message = {
data = 0x56060af8fa20 "select \n public.st_union(\n cast(cast(null as raster) as raster),\n cast(sample_12.gid as int4)) over (partition by sample_12.hip2 order by sample_12.hip2) as c5 \n from \n public."..., len = 248, maxlen = 1024, cursor = 248}
local_sigjmp_buf = {{__jmpbuf = {140730199145216, 639202057558593934, 1, 94583954237496, 140730199146080, 94583954207936, 639202057451639182, 6570304840499761550},
__mask_was_saved = 1, __saved_mask = {__val = {0, 140730199154375, 140730199154330, 140730199154642, 0, 139637976727552, 94583954207936, 140730199145488,
17693867717872550656, 140730199145648, 94583944247327, 206158430256, 140730199145672, 140730199145472, 17693867717872550656, 94583953857040}}}}
send_ready_for_query = false
disable_idle_in_transaction_timeout = false
__func__ = "PostgresMain"
#16 0x000056060a473208 in BackendRun (port=0x56060afdf4c0, port=0x56060afdf4c0) at ./build/../src/backend/postmaster/postmaster.c:4448
av = 0x56060afe6990
maxac = <optimized out>
ac = 1
i = 1
av = <optimized out>
i = <optimized out>
__func__ = "BackendRun"
#17 BackendStartup (port=0x56060afdf4c0) at ./build/../src/backend/postmaster/postmaster.c:4139
bn = <optimized out>
__func__ = "BackendStartup"
save_errno = <optimized out>
#18 ServerLoop () at ./build/../src/backend/postmaster/postmaster.c:1704
port = 0x56060afdf4c0
i = <optimized out>
rmask = {fds_bits = {32, 0 <repeats 15 times>}}
selres = <optimized out>
now = <optimized out>
readmask = {fds_bits = {56, 0 <repeats 15 times>}}
nSockets = 6
last_lockfile_recheck_time = 1591255331
last_touch_time = 1591255331
__func__ = "ServerLoop"
#19 0x000056060a47412f in PostmasterMain (argc=5, argv=0x56060af89930) at ./build/../src/backend/postmaster/postmaster.c:1377
opt = <optimized out>
userDoption = <optimized out>
listen_addr_saved = <optimized out>
i = <optimized out>
output_config_variable = <optimized out>
__func__ = "PostmasterMain"
#20 0x000056060a1ddeed in main (argc=5, argv=0x56060af89930) at ./build/../src/backend/main/main.c:228
No locals.
Type: application/sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200604/c4246e8b/attachment-0001.bin>
Type: application/gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200604/c4246e8b/attachment-0001.gz>
