[postgis-devel] Cast GeoJSON to geometry like with WKT
    Felix Kunde
    felix-kunde at gmx.de
    Fri Mar  6 01:50:18 PST 2020
Hey there,
maybe there's already an open issue/ticket for this - did not search that long. So sorry just in case.
I'm happy about the new geometry::jsonb cast feature, but just found out that it breaks my audit trail software where I log changes as JSONB.
One feature is to restore previous versions, so transferring the JSONB logs back to their relational counterparts with jsonb_populate_record function.
Before, this was no problem as the WKB ended up in JSONB and could be reused to create PostGIS geometries.
But with the new behavior, I can only use ST_GeomFromGeoJSON if I'm not mistaken.
It would be nice if there would be a more "native" way, e.g. like what we have for WKT where I can write 'POINT(1 1)'::geometry.
So something like: SELECT '{"type":"Point","coordinates":[1,1]}'::geometry
I'm not 100% sure if this would solve my problem ^^
Is it something you like to have and think it's possible?
I might try to implement, if you think it's shouldn't be too hard.
Kind regards
Felix
PS: Btw, was there ever a discussion to do WKB::text = WKT? :)
