[postgis-devel] GEOS 3.8.1
Yuri Astrakhan yuriastrakhan at gmail.com
Tue Mar 10 18:35:37 PDT 2020
Paul, thanks for the heads up!
I just checked the postgis docker image at [1], and it seems like it is
still using Postgis v3.0.0 and not 3.0.1 that was released almost a month
ago.  I suspect GEOS is even older. Is there a way to expedite package
repository to update to 3.0.1 and latest GEOS?  It would be wonderful to
just use it directly from the repository and/or docker hub rather than
hand-compile it.
Thanks!
- [1]
https://github.com/postgis/docker-postgis/blob/master/12-3.0/Dockerfile
On Tue, Mar 10, 2020 at 2:41 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> The latest patch release of GEOS stable branch is out.
> We recommend you upgrade as soon as possible, there is a fixed bug that
> can be exercised to crash backend services.
> There is also a fixed performance issue relative to the 3.7 branch.
> http://download.osgeo.org/geos/geos-3.8.1.tar.bz2
> Improvements:
>   - Stack allocate line segments in OverlapUnion (Paul Ramsey)
>   - Avoid returning non-empty CoordinateSequence from empty Point
>     (#1001, Dan Baston)
>   - Avoid assertion failure with MSVC 2017 / 2019 (#1002, Dan Baston)
>   - Remove whitespace from end of GEOSversion() output (azhi)
>   - Improve performance of GEOSisValid (#1008, Dan Baston)
>   - Avoid changing MultiLineString component order in GEOSReverse
>     (#1013, Dan Baston)
>   - Fix missing vtable for LineString and CoordinateArraySequenceFactory
>     (#299 and #1016, Evgen Bodunov)
>   - Reduce performance regression in GEOSBuffer (#1020)
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20200310/545fc4cf/attachment.html>
