[postgis-devel] Cast GeoJSON to geometry like with WKT
rmrodriguez at carto.com
Mon Mar 30 09:40:19 PDT 2020
It contains a big polygon:
[{"geomref" : "48061", "value" :
{"type":"MultiPolygon","coordinates":[[[[-97.167369,26.413108], ... ,
[-97.223544,26.411478],[-97.167369,26.413108]]]]}}]
It comes from a series of functions calls
(https://github.com/CartoDB/observatory-extension/blob/6a063ca0eb33043f22e47171fc328aa50a6efc39/src/pg/sql/44_observatory_geometries.sql#L127)
so I've tried to extract a smaller example that works with Postgis 2.5
and it doesn't in 3.0 but I still haven't been able to.
Note that both 2.5 and 3.0 and running under PG12
(https://travis-ci.org/github/CartoDB/observatory-extension/builds/668806964)
so I'm discarding a change there. I'll share a smaller testable repro
once I get it.
On Mon, Mar 30, 2020 at 5:58 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Wait, what? what is in 'value'?
> > On Mar 30, 2020, at 8:56 AM, rmrodriguez at carto.com wrote:
> > I've been bitten by this today. This code used to work in Postgis 2.x:
> > SELECT (data->0->>'value')::Geometry
> > But it now requires to be called as:
> > ST_GeomFromGeoJSON(data->0->>'value')
> > So I wouldn't be opposed to backporting this to 3.0 if it were to be
> > implemented.
> > Raúl Marín Rodríguez
> > carto.com
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
carto.com
