[postgis-devel] Cast GeoJSON to geometry like with WKT
Regina Obe
lr at pcorp.us
Mon Mar 30 09:52:34 PDT 2020
Curious does this work
SELECT (data->0->'value')::Geometry
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On
> Behalf Of rmrodriguez at carto.com
> Sent: Monday, March 30, 2020 12:40 PM
> To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Subject: Re: [postgis-devel] Cast GeoJSON to geometry like with WKT
> It contains a big polygon:
> [{"geomref" : "48061", "value" :
> {"type":"MultiPolygon","coordinates":[[[[-97.167369,26.413108], ... , [-
> 97.223544,26.411478],[-97.167369,26.413108]]]]}}]
> It comes from a series of functions calls
> (https://github.com/CartoDB/observatory-
> extension/blob/6a063ca0eb33043f22e47171fc328aa50a6efc39/src/pg/sql/4
> 4_observatory_geometries.sql#L127)
> so I've tried to extract a smaller example that works with Postgis 2.5 and it
> doesn't in 3.0 but I still haven't been able to.
> Note that both 2.5 and 3.0 and running under PG12
> (https://travis-ci.org/github/CartoDB/observatory-
> extension/builds/668806964)
> so I'm discarding a change there. I'll share a smaller testable repro once I get
> it.
> On Mon, Mar 30, 2020 at 5:58 PM Paul Ramsey
> <pramsey at cleverelephant.ca> wrote:
> > Wait, what? what is in 'value'?
> > > On Mar 30, 2020, at 8:56 AM, rmrodriguez at carto.com wrote:
> > > I've been bitten by this today. This code used to work in Postgis 2.x:
> > > SELECT (data->0->>'value')::Geometry ``` But it now requires to be
> > > called as:
> > > ST_GeomFromGeoJSON(data->0->>'value')
> > > So I wouldn't be opposed to backporting this to 3.0 if it were to be
> > > implemented.
> > > Ra l Mar n Rodr guez
> > > carto.com
> > > _______________________________________________
> > > postgis-devel mailing list
> > > https://lists.osgeo.org/mailman/listinfo/postgis-devel
> carto.com
