[postgis-devel] on parallel and recursive make
rmrodriguez at carto.com
Wed Nov 4 05:21:00 PST 2020
On Wed, Nov 4, 2020 at 1:48 PM Sandro Santilli <strk at kbt.io> wrote:
> The recent change allowed to run all tests at once, so we need to
> build all components at once, and if each of the components is built
> in parallel, they end up building liblwgeom in parallel.
And what's the benefit of running all tests at once? The CI builds
seem to be taking the same time.
Is this change worth all the troubles that it's causing? Maybe I'm not
seeing how it improves things.
Raúl Marín Rodríguez
carto.com
