[postgis-devel] Proposal: ST_Overlay function
Martin Davis mtnclimb at gmail.com
Fri Nov 27 09:33:53 PST 2020
Thanks for the vote of approval!
And also for the thought-provoking ideas about a function signature for
full overlay, and about grid-based parallelization.  Will keep those in
mind for if and when there is time to work on this.
On Thu, Nov 26, 2020 at 2:05 PM Andrew Joseph <ap.joseph at live.com> wrote:
> This would be incredibly useful and likely become one of the most used
> functions in Postgis!
> Personally I think the simplest most intuitive function definition would be
> st_polygonal_overlay(idpoly[]) RETURNS SETOF idpolyportion;
> CREATE TYPE idpoly(
>   id integer,
>    geom geometry(Polygon)
> CREATE TYPE idpoly_portion(
>   parent_ids integer[],
> This would make it trivial to recombine the geometries with the originals.
> The biggest question I’d have would be how would parallelization work?
> Might be helpful to have another function that would create an ideal grid
> for clipping input geometries maybe something like:
> st_create_parallel_overlay_grid(geoms geometry[], numcores integer,
> max_mem_per_grid integer) RETURNS box2d;
> This way you could spread out st_polygonal_overlay across cores, then
> recombine using st_union by comparing parent_ids.
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows 10
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20201127/e54dda74/attachment.html>
