[postgis-devel] Much slower processing on GEOS 3.9.0 versus 3.8.0 for geodesic area calculation
Paul Ramsey
pramsey at cleverelephant.ca
Mon Apr 26 08:41:51 PDT 2021
So, to be clearer about how to interface with -devel with your issues:
- data, in a dump file, as small as possible to demonstrate the issue,
preferably just one table, generated with pg_dump -d database -t table
--no-owner, ideally small enough to attach to a trac ticket
- the ideal size of data is "no data at all", many bugs can be reduced to
one geometry that can be part of the SQL call that exercises the condition
- SQL, in a sql file, again as small as possible, one statement ideally,
with as few functions as possible
The goal here is to allow a dev to copy your SQL and drop it into a console
in one cut-paste step, because given our finite time base, spending a lot
of time trying to replicate a situation and then getting a "null result"
where everything still works fine is hugely annoying. I'm not going to
attempt to replicate your setup as described because there are way too many
degrees of freedom, I'm almost guaranteed to get a non replicable
situation, and have wasted whatever time I invest in it.
People who invest the time to reduce their problem to a cut'paste example
get responses and fixes surprisingly fast. Those who don't wonder why OSS
developers are such standoffish bastards. There's a continuum of quality
between "it's broken" and "here's a one line SQL statement that does
exactly this thing which is not what is supposed to happen", but the closer
you get to the far end, the faster and better things will go. I recognize
that regressions and multi-version issues are the hardest, but here too
time reducing the problem to the minimum degrees of freedom will result in
attention.
In answer to your question: GEOS has no direct linkage to proj, and it
makes little sense that ST_Area(geometry::geography) would be sensitive to
GEOS version, as neither (the function nor the cast) enters the GEOS code
line at all. (They do, however, both enter the proj code line.)
P.
On Mon, Apr 26, 2021 at 8:11 AM Marco Boeringa <marco at boeringa.demon.nl>
wrote:
> One more thing to note related to this issue is that the UPDATE taking
> place is in a high multi-threaded application, with individual UPDATE
> statements for each record, however batched in hundreds or thousands of
> records inside a single transaction.
> There is a known issue with PROJ 6+ where creating a transformation object
> is considerably more costly than in PROJ <=5 (
> https://trac.osgeo.org/postgis/ticket/4372), but both installations I
> tested for GEOS 3.8.0 and GEOS 3.9.0 are running PROJ 6.3.1, as the 'SELECT
> postgis_full_version()' showed, *unless* the answer to my last question:
> * Is GEOS dependency on PROJ dynamic like PostGIS, or is it baked in? What
> I mean is, if I see 'SELECT postgis_full_version' return 'PROJ="6.3.1"' as
> it does in my installation, is GEOS / libgeos then using the exact same
> version 6.3.1, or might it be using an older version, e.g. PROJ 5.x?
> is that GEOS *does* have its own PROJ version, and my non-updated original
> installation of GEOS 3.8.0 is using a lower than PROJ 6 version, while the
> GEOS 3.9.0 is on 6 or higher. Anyone can answer the above?
> Marco
> Op 26-4-2021 om 15:52 schreef Marco Boeringa:
> Hi Raúl,
> "Does the slowdown also appears if you only do the casting to geography
> (no ST_Area)?"
> I was in the process of restoring a VM and restarting a process. Answering
> this question will require me to stop that process and restore the VM again
> from backup, which is quite time consuming. It will therefor take some time
> to answer this.
> "When you update GEOS, are you updating any other package at the same
> time?"
> I only selected 'libgeos-3.9.0' from the Synaptic Package Manager. I can't
> remember if it automatically selected other dependencies of that package to
> update as well, but I certainly didn't select anything else myself at the
> same time. You probably have a better idea of what dependencies might have
> been updated in other to support 'libgeos-3.9.0'.
> I do have one question for you as well:
> Regards,
> Marco
> Op 26-4-2021 om 14:42 schreef Raúl Marín:
> Hi Marco,
> Two questions:
> * Does the slowdown also appears if you only do the casting to geography
> (no ST_Area)?
> * When you update GEOS, are you updating any other package at the same
> time?
> Regards,
> Raúl.
> On 2021-04-26 12:03, Marco Boeringa wrote:
> Hi all,
> I am seeing a very significant performance regression (104x) when
> attempting to calculate geodesic area using PostGIS after upgrading GEOS
> from 3.8.0 to 3.9.0:
> POSTGIS 3.1.1 / GEOS 3.8.0: 1m52s
> POSTGIS 3.1.1 / GEOS 3.9.0: 3h(!)14m45s
> This makes it impossible for me to process planet level OpenStreetMap
> data, and I had to restore a backup to get back to a usable situation.
> The actual code run is nothing more than what the PostGIS manual shows:
> "float ST_Area(geography geog, boolean use_spheroid=true);"
> Note that the OpenStreetMap data, as imported by osm2pgsql, is stored in
> PostGIS in WGS1984 / SRID 4326 as 'geometry', so in order to use it in
> 'ST_Area', the data is simply cast to 'geography':
> "ST_Area(way::geography,true)"
> Nothing else happens in this part of the processing when the performance
> regression is visible. In fact, other more complicated parts of the code
> that call more advanced functions like 'ST_SimplifyVW' / 'ST_Transform' /
> 'ST_ChaikinSmoothing' run at expected / normal speed in GEOS 3.9.0 compared
> to 3.8.0, so it is not an overall slower processing that is happening.
> The postgis_full_version results for these setups are:
> - POSTGRESQL 13.2 / POSTGIS 3.1.1 / GEOS 3.8.0:
> PostGIS version: POSTGIS="3.1.1 aaf4c79" [EXTENSION] PGSQL="130"
> GEOS="3.8.0-CAPI-1.13.1 " PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1"
> LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
> - POSTGRESQL 13.2 / POSTGIS 3.1.1 / GEOS 3.9.0:
> GEOS="3.9.0-CAPI-1.16.2" PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1"
> I am not entirely sure why 'postgis_full_version' is showing 'PGSQL="130"'
> instead of 'PGSQL="132"', as I am definitely on 13.2, 'SELECT version()'
> returns:
> PostgreSQL 13.2 (Ubuntu 13.2-1.pgdg20.04+1) on x86_64-pc-linux-gnu,
> compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
> Note that the installation of PostgreSQL / PostGIS is based on the plain
> vanilla one as available from the official apt repository for PostgreSQL:
> http://apt.postgresql.org/pub/repos/apt/
> while GEOS was updated to 3.9.0 from the UbuntuGIS repository:
> https://launchpad.net/~ubuntugis/+archive/ppa/
> *** STEPS to reproduce ***
> - Load some OpenStreetMap as WGS1984 / SRID 4326 using osm2pgsql
> - Ensure you have the default POSTGRESQL 13.2 / POSTGIS 3.1.1 / GEOS 3.8.0
> version installed as from the official repository
> - Create a column to store the geodesic area data
> - UPDATE the column using "ST_Area(way::geography,true)" and note timing
> - Now update GEOS to 3.9.0 from the UbuntuGIS repository
> - Ensure GEOS is properly at 3.9.0 by calling 'SELECT
> - Run UPDATE a second time with "ST_Area(way::geography,true)" and again
> note timing
> This should show a major difference.
> Marco
> postgis-devel mailing listpostgis-devel at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210426/7bfc07a9/attachment-0001.html>
