[postgis-devel] Error making postgis
Ayoub FATIHI
ayoubfatihi1999 at gmail.com
Fri Apr 30 18:46:49 PDT 2021
Actually ther was this warnings:
lwgeom_geos.c:147:2: warning: implicit declaration of function
‘GEOSCoordSeq_copyToBuffer’; did you mean ‘GEOSCoordSeq_clone’?
[-Wimplicit-function-declaration]
147 | GEOSCoordSeq_copyToBuffer(cs, (double*) pa->serialized_pointlist,
(dims == 3), 0);
| GEOSCoordSeq_clone
lwgeom_geos.c: In function ‘ptarray_to_GEOSCoordSeq’:
lwgeom_geos.c:280:8: warning: implicit declaration of function
‘GEOSCoordSeq_copyFromBuffer’ [-Wimplicit-function-declaration]
280 | sq = GEOSCoordSeq_copyFromBuffer((const double*)
pa->serialized_pointlist, pa->npoints, FLAGS_GET_Z(pa->flags),
FLAGS_GET_M(pa->flags));
lwgeom_geos.c:280:6: warning: assignment to ‘GEOSCoordSeq’ {aka ‘struct
GEOSCoordSeq_t *’} from ‘int’ makes pointer from integer without a cast
[-Wint-conversion]
And this warning was repeated a bunch of time :
gcc -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Werror=vla -Wendif-labels
-Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type
-Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard
-Wno-format-truncation -Wno-stringop-truncation -O2 -fPIC
"-I../../liblwgeom" -I/usr/include -I/usr/include/libxml2
-I/usr/include/json-c -DNDEBUG -std=gnu99 -g -O2 -fno-math-errno
-fno-signed-zeros -I/usr/include/gdal "-I../../libpgcommon" -I../rt_core
-I. -I./ -I/usr/local/pgsql/include/server
-I/usr/local/pgsql/include/internal -D_GNU_SOURCE -c -o rtpg_internal.o
rtpg_internal.c
In file included from /usr/include/gdal/cpl_port.h:66,
from /usr/include/gdal/gdal.h:45,
from ../rt_core/librtcore.h:126,
from rtpostgis.h:39,
from rtpg_internal.h:33,
from rtpg_internal.c:34:
/usr/include/gdal/cpl_config.h:296: warning: "PACKAGE_URL" redefined
296 | #define PACKAGE_URL ""
In file included from /usr/local/pgsql/include/server/c.h:54,
from /usr/local/pgsql/include/server/postgres.h:46,
from rtpg_internal.c:31:
/usr/local/pgsql/include/server/pg_config.h:806: note: this is the location
of the previous definition
806 | #define PACKAGE_URL "https://www.postgresql.org/"
Here is the full output :
https://github.com/ayoubft/postgis_error_file/blob/main/make_result.txt
<https://github.com/ayoubft/postgis_error_file/blob/main/make_result.txt>
FATIHI Ayoub
On Sat, May 1, 2021 at 12:40 AM Ayoub FATIHI <ayoubfatihi1999 at gmail.com>
wrote:
> Hi community,
> I was re-installing PostGIS with PostgreSQL from source.
> And I have this problem :
> Postgres compile just fine. But ...
> When I run make for postgis, I get this error:
> collect2: error: ld returned 1 exit status
> make[2]: *** [Makefile:84: raster2pgsql] Error 1
> make[2]: Leaving directory '/usr/local/src/postgis/raster/loader'
> make[1]: *** [Makefile:35: rtloader] Error 2
> make[1]: Leaving directory '/usr/local/src/postgis/raster'
> make: *** [GNUmakefile:22: all] Error 1
> Noting also that config when done says:
> PostGIS is now configured for x86_64-pc-linux-gnu
> -------------- Compiler Info -------------
> C compiler: gcc -std=gnu99 -g -O2 -fno-math-errno
> -fno-signed-zeros
> C++ compiler (Wagyu): gcc -std=c++11 -x c++
> CPPFLAGS: -I/usr/include -I/usr/include/libxml2
> LDFLAGS: -lm
> SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
> -------------- Additional Info -------------
> Interrupt Tests: DISABLED use: --with-interrupt-tests to enable
> -------------- Dependencies --------------
> GEOS config: /usr/bin/geos-config
> GEOS version: 3.8.0
> GDAL config: /usr/bin/gdal-config
> GDAL version: 3.0.4
> PostgreSQL config: /usr/local/pgsql/bin/pg_config
> * PostgreSQL version: PostgreSQL 14devel*
> PROJ4 version: 63
> Libxml2 config: /usr/bin/xml2-config
> Libxml2 version: 2.9.10
> JSON-C support: yes
> protobuf support: yes
> protobuf-c version: 1003003
> PCRE support: yes
> Perl: /usr/bin/perl
> --------------- Extensions ---------------
> PostGIS Raster: enabled
> PostGIS Topology: enabled
> SFCGAL support: disabled
> Address Standardizer support: enabled
> -------- Documentation Generation --------
> xsltproc: /usr/bin/xsltproc
> xsl style sheets:
> dblatex:
> convert:
> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> configure: WARNING: --------- GEOS VERSION WARNING ------------
> configure WARNING: You are building against GEOS 3.8.0.
> configure: WARNING:
> configure: WARNING: To take advantage of _all_ the features of
> configure: WARNING: PostGIS, GEOS 3.9.0 or higher is required.
> configure: WARNING:
> configure: WARNING: For _many_ features, GEOS 3.6.0 is enough.
> configure: WARNING:
> configure: WARNING: We recommend GEOS 3.8.0 or higher
> configure: WARNING:
> configure: WARNING: You can download the latest versions from
> configure: WARNING: http://geos.osgeo.org/
> configure: WARNING:
> Any ideas how to solve this problem ?
> FATIHI Ayoub
FATIHI Ayoub
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210501/2da73b74/attachment-0001.html>
