[postgis-devel] the_geom
Regina Obe lr at pcorp.us
Fri Aug 20 15:46:26 PDT 2021
Well you don’t have commit rights to the PostGIS master repo so you can’t really screw up the real master.  It should force you to do a pull request which would be tested.
So go for it.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bruce Rindahl
Sent: Friday, August 20, 2021 5:45 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: [postgis-devel] the_geom
Okay I cloned the master github, made all the replacements, and have a commit ready.  Do I push this without screwing everything up?
On Fri, Aug 20, 2021 at 2:22 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Oh I missed that. Yah I think we should keep the change limited to the xml files.
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org <mailto:postgis-devel-bounces at lists.osgeo.org> ] On Behalf Of Martin Davis
Sent: Friday, August 20, 2021 4:47 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org> >
For starters just the the_geom usages in the doc XML files can be targetted.  That's only 224 hits in 22 files.
On Fri, Aug 20, 2021 at 11:58 AM Bruce Rindahl <bruce.rindahl at gmail.com <mailto:bruce.rindahl at gmail.com> > wrote:
FYI
Just a quick spot check for 'the_geom' found 6863 hits in 304 files.  That would be an impressive commit.
Bruce
postgis-devel mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210820/8c39ef13/attachment.html>
