[postgis-devel] PostGIS installation dependencies
Nikhil Shetty
nikhil.dba04 at gmail.com
Mon Aug 30 09:25:31 PDT 2021
Hi Regina,
Thank you so much, I got the dependent packages from common repo -
https://download.postgresql.org/pub/repos/yum/common/redhat/rhel-7-x86_64/
Thanks,
Nikhil
On Sat, Aug 28, 2021 at 1:44 AM Regina Obe <lr at pcorp.us> wrote:
> Oops I forgot that for older, Devrim has a custom repo.
> Try adding
> That has all the dependencies needed for Red Hat 7
> Not tested but something like this might work
> sudo tee /etc/yum.repos.d/pgdg.repo<<EOF
> [pgdg-13]
> name=PostgreSQL for 13 RHEL/CentOS 7 - x86_64
> baseurl=
> https://download.postgresql.org/pub/repos/yum/13/redhat/rhel-7-x86_64/
> enabled=1
> gpgcheck=0
> [pgdg-depends]
> name=PostgreSQL RHEL/CentOS 7 - x86_64 common
> baseurl=
> enabled=1
> gpgcheck=0
> EOF
> Then do your yum update yum install as usual.
> *From:* Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Friday, August 27, 2021 12:17 PM
> *To:* 'PostGIS Development Discussion' <postgis-devel at lists.osgeo.org>
> *Subject:* RE: [postgis-devel] PostGIS installation dependencies
> I think you are missing epel is my guess.
> Checkout these instructions:
> https://people.planetpostgresql.org/devrim/index.php?/archives/107-Installing-PostGIS-3.1-and-PostgreSQL-13-on-CentOS-8.html
> I think the instructions are pretty much the same for RHEL but I haven’t
> tried on RHEL.
> Thanks,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org
> <postgis-devel-bounces at lists.osgeo.org>] *On Behalf Of *Nikhil Shetty
> *Sent:* Friday, August 27, 2021 10:49 AM
> *To:* postgis-devel at lists.osgeo.org
> *Subject:* [postgis-devel] PostGIS installation dependencies
> Hi Team,
> We are installing PostgreSQL 13.4 and along with that we would like to
> have PostGIS3.1.
> When installing PostGIS 3.1, we are getting dependency errors for a few
> packages.
> --> Finished Dependency Resolution
> Error: Package: postgis31_13-3.1.2-1.rhel7.x86_64
> (/postgis31_13-3.1.2-1.rhel7.x86_64)
> Requires: geos39 >= 3.9.1
> Requires: libgdal.so.28()(64bit)
> Requires: proj72 >= 7.2.1
> Requires: gdal32-libs >= 3.2.3
> Requires: libgeotiff16
> Error: Package: postgis31_13-client-3.1.2-1.rhel7.x86_64
> (/postgis31_13-client-3.1.2-1.rhel7.x86_64)
> You could try using --skip-broken to work around the problem
> You could try running: rpm -Va --nofiles --nodigest
> Operating System is OEL7.9
> I tried creating rpm from source for geos-3.9.1 and installed the rpm but
> I got the same error as above
> -0-nikhil_shetty at ms15q01nt-qujo18341101:~/rpmbuild/RPMS/x86_64 $ rpm -qa
> | grep geos
> *geos*38-3.8.1-1.rhel7.x86_64
> *geos*-debuginfo-3.9.1-1.el7.x86_64
> *geos*-3.9.1-1.el7.x86_64
> Is there anyway I can get these rpms directly from some official source?
> postgis-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210830/7a245b7a/attachment.html>
