[postgis-devel] PSC Vote: PostGIS 3.1.4 / 3.0. 4 planned release around 3.2.0alpha1 time
Paul Ramsey pramsey at cleverelephant.ca
Tue Aug 31 08:45:17 PDT 2021
> On Aug 30, 2021, at 7:52 AM, Regina Obe <lr at pcorp.us> wrote:
> We have quite a few crasher fixes and other annoyances slated for PostGIS
> 3.1 and 3.0.
> For 2.5 and 2.4, I don't think there is enough to warrant a release until we
> do the official release of 3.2.0 at which point we'll EOL 2.4 as well.
> +1
> Is everyone okay with releasing , 3.0.4 , 3.1.4 around the time of
> 3.2.0alpha1?
> Of course I volunteer to do the release unless someone else wants to.
> So in about a week.
> https://trac.osgeo.org/postgis/query?status=closed&milestone=PostGIS+2.4.10&
> milestone=PostGIS+2.5.6&milestone=PostGIS+3.2.0&milestone=PostGIS+3.0.4
> Fixes that would be in these would be
>  - #4941, Fix loose mbr in topology.face on update (Sandro Santilli)
>  - #4854, Fix type of TopoGeometry receiving different-type
>           TopoGeometry components (Sandro Santilli)
>  - #4871, TopoGeometry::geometry cast returns NULL for empty
>           TopoGeometry objects (Sandro Santilli)
>  - #4817, Handle complex compound coordinate systems (Paul Ramsey)
>  - Support newer proj versions that have deprecated pj_get_release (Paul
> Ramsey)
>  - #4835, Adjust geodetic tolerance for calculations (Paul Ramsey)
>  - #4853, DBSCAN cluster not formed when recordset length equal to
> minPoints (Dan Baston)
>  - #4844, Repair axis order handling for polar coordinate systems (Paul
> Ramsey)
>  - #4863, Update bboxes after scale/affine coordinate changes (Paul Ramsey)
>  - #4918, Fix rare crash in st_minpossiblevalue() (Paul Ramsey)
>  - #4949, Swapped coordinates for N/E planar systems (Paul Ramsey)
>  - GI617, Fix typo in setting of INVMINDIST (Charles Karney)
>  - #4326, Fix CircularPolygon area calculation (Paul Ramsey)
>  - #4917, Fix crasher with '-' regclass (Paul Ramsey)
>  - #4919, Rare crash in selectivity calculation (Paul Ramsey)
>  - #4926, Preserve SRID on unions of empty geometry (Paul Ramsey)
>  - #4740, Round values in geography_distance_tree
>           as we do on geography_distance (Raúl Marín, Paul Ramsey, Regina
> Obe)
>  - #4959, Drop Colorado state files also drops national county tables
> (Regina Obe)
>  - #4958, TIGER2020 fix faces and add Tabblock20 (Regina Obe)
>  - #4968, Update autogen.sh to handle autoconf 2.71 issues (Raúl Marín,
> Regina Obe)
>  - #4910, Allow repeated points in GML input poslists (Paul Ramsey)
>  - #4916, #4770, #4724, #4916, Crashes in aggregate functions (Paul Ramsey)
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
