[postgis-devel] PostGIS benchmark
Bruce Rindahl
bruce.rindahl at gmail.com
Wed Dec 1 18:36:18 PST 2021
Fwiw I have been doing some testing to allow benchmark testing on a berrie
type machine. The goal is to set up an environment to implement
https://git.osgeo.org/gitea/postgis/postgis-performance
I have installed stow
https://linuxconfig.org/how-to-use-gnu-stow-to-manage-programs-installed-from-source-and-dotfiles
so I can have various versions of proj, geos, and gdal precompiled and
ready to go for compiling PostGIS against any combination needed.
PostGIS doesn't play well with stow due to
https://trac.osgeo.org/postgis/ticket/635
but compiling is not too slow. It might be nice to do some benchmark
testing especially with all the discussion about the new index methods
available.
Let me know if this helps
On Wed, Dec 1, 2021, 1:10 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> So about this plan, I don't see the ALTER OPERATOR CLASS recipe that can
> do the thing we want.
> https://www.postgresql.org/docs/14/sql-alteropclass.html
> What's the magic incantation?
> > On Dec 1, 2021, at 8:30 AM, Regina Obe <lr at pcorp.us> wrote:
> >> Initially there was a patch in patchset making user specify sorting
> function
> >> during CREATE INDEX ON table USING gist(column) WITH
> >> (sortfunction=zcurve). But everyone said that it's unnessecary
> complication and
> >> we just made the function part of the opclass.
> >> But sorting build was not meant to be default!
> >> I'm going to work on this in December, so let's figure out what exactly
> do we
> >> want from PostgreSQL 15?
> >> I'm planning to work on:
> >> 1. Fix the concurrency problem in IndexOnlyScan that Peter G. pointed
> out [0]
> >> This will further slow down GiST queries a little, sorry.
> >> 2. Sorting items within leaf page in tid order, not provided sorting
> function.
> >> 3. Make better splits of leaf pages. Currently we choose how to split
> leaf pages
> >> solely by sorting function. I want to use split function too. This will
> consume
> >> slightly more memory, but will build better index.
> >> Do we need some functionality to easily enable\disable sorting build? I
> think
> >> chances are very high that we can make it better. But it still will be
> neither
> >> perfect, nor better than buffered build.
> >> Thanks!
> >> Best regards, Andrey Borodin.
> > [Regina Obe]
> > I don't think I was in this discussion about CREATE INDEX ON table USING
> gist(column) WITH
> > What was the unnecessary complication? Was it deemed "user-facing" too
> complicated
> > or "under the hood" too complicated.
> > For user-facing I don't see it as too complicated. Granted it is a bit
> extra.
> > But if it is deemed always not the absolute best, I feel a configure
> option is fine.
> > It's only giving users redundant equally good options that I would
> consider too complicated.
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20211201/efa0f392/attachment.html>
