[postgis-devel] PostGIS 3.2.0beta3 is released
Greg Troxel gdt at lexort.com
Sat Dec 4 17:43:58 PST 2021
"Regina Obe" <lr at pcorp.us> writes:
> Source: https://download.osgeo.org/postgis/source/postgis-3.2.0beta3.tar.gz
I locally updated the pkgsrc postgis entry and it built and packaged OK,
after
  removing the LDFLAGS patch I submitted upstream (thanks)
  adjusting the set of SQL upgrade files (normal)
I ran tests on NetBSD 9 amd64 against postgresq1 10, the version I have
installed (for no good reason), even though I intend to move to 12 for
semi-production use.
Note that I have gdal 3.4.0, which while a release feels bleeding edge.
I have not committed this to pkgsrc.  I also have old proj 6.3.2, only
because I haven't gotten around to dealing with the brave new world of
different proj-data and network access.  But gdal and proj work fine
with qgis, as far as I can tell, as does my postgis 3.1.4 installation.
Note also that 3.1.4 is installed, and I am testing 3.2.0beta3 from the
build tree.
My memory of previous version tests is that they basically work, except
there is a raster crash, which has been happening for a long time.  This
time, I got a crash in geography:
PostgreSQL 10.18 on x86_64--netbsd, compiled by gcc (nb3 20190319) 7.4.0, 64-bit
  Postgis 3.2.0beta3 - (1a89e36) - 2021-12-05 01:26:39
  scripts 3.2.0beta3 1a89e36
  raster scripts 3.2.0beta3 1a89e36
  GEOS: 3.10.1-CAPI-1.16.0
  PROJ: 6.3.2
  GDAL: GDAL 3.4.0, released 2021/11/04
Running tests
   after-create-script /tmp/work/databases/postgresql-postgis2/work/postgis-3.2.0beta3/regress/hooks/hook-after-create.sql .. ok
   ./regress/core/affine .. ok in 63 ms
   ./regress/core/bestsrid .. ok in 56 ms
   ./regress/core/binary .. ok in 78 ms
   ./regress/core/boundary .. ok in 55 ms
   ./regress/core/chaikin .. ok in 55 ms
   ./regress/core/filterm .. ok in 54 ms
   ./regress/core/cluster .. ok in 67 ms
   ./regress/core/concave_hull .. ok in 216 ms
   ./regress/core/ctors .. ok in 55 ms
   ./regress/core/curvetoline .. ok in 54 ms
   ./regress/core/dump .. ok in 56 ms
   ./regress/core/dumppoints .. ok in 56 ms
   ./regress/core/dumpsegments .. ok in 55 ms
   ./regress/core/empty .. ok in 63 ms
   ./regress/core/estimatedextent .. ok in 118 ms
   ./regress/core/forcecurve .. ok in 54 ms
   ./regress/core/flatgeobuf .. ok in 70 ms
   ./regress/core/geography ..Died at /tmp/work/databases/postgresql-postgis2/work/postgis-3.2.0beta3/regress/run_test.pl line 744.
   failed (psql exited with an error: /tmp/pgis_reg/test_19_out)
and test_19_out, timestamp 20:31:28 2021
  psql:geography.sql:11: server closed the connection unexpectedly
          This probably means the server terminated abnormally
          before or while processing the request.
  psql:geography.sql:11: connection to server was lost
The end of regress_log is
  COMMENT
  COMMENT
  COMMENT
  NOTICE:  schema "public" already exists, skipping
  CREATE SCHEMA
  SET
  CREATE FUNCTION
  CREATE EVENT TRIGGER
and my /usr/pkg/pgsql/errlog
  2021-12-04 20:31:27.734 EST [14650] STATEMENT:  select ST_3DMakeBox('POINT(0 0)', 'SRID=3;POINT(1 1)');
  2021-12-04 20:31:28.293 EST [21988] WARNING:  stats for "t.g" do not exist
  2021-12-04 20:31:28.294 EST [21988] WARNING:  stats for "t.g" do not exist
  2021-12-04 20:31:28.295 EST [21988] WARNING:  stats for "t.g" do not exist
  2021-12-04 20:31:28.304 EST [21988] WARNING:  stats for "c1.g" do not exist
  2021-12-04 20:31:28.304 EST [21988] WARNING:  stats for "c2.g" do not exist
  2021-12-04 20:31:28.304 EST [21988] WARNING:  stats for "p.g" do not exist
  2021-12-04 20:31:28.306 EST [21988] WARNING:  stats for "c2.g" do not exist
  2021-12-04 20:31:28.313 EST [21988] WARNING:  stats for "p.g" do not exist
  2021-12-04 20:31:28.313 EST [21988] WARNING:  stats for "c1.g" do not exist
  2021-12-04 20:31:28.315 EST [21988] WARNING:  stats for "p.g" do not exist
  2021-12-04 20:31:28.534 EST [15485] ERROR:  mixed geometry type is not supported
  2021-12-04 20:31:28.534 EST [15485] STATEMENT:  select 'PL1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
              select ST_AsFlatGeobuf(q) from (values
                  ('POINT (1 2)'::geometry),
                  ('POINT (3 4)'::geometry),
                  ('POLYGON ((35 10, 45 45, 15 40, 10 20, 35 10), (20 30, 35 35, 30 20, 20 30))'::geometry)
              ) q)
  2021-12-04 20:31:28.833 EST [1047] LOG:  server process (PID 16190) was terminated by signal 6: Abort trap
  2021-12-04 20:31:28.833 EST [1047] DETAIL:  Failed process was running: SELECT c, abs(ST_Distance(ply::geography, pt::geography) - _ST_DistanceUnCached(ply::geography, pt::geography)) < 0.01 FROM
          ( VALUES
          ('geog_distance_cached_1a', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5 5)'),
          ('geog_distance_cached_1b', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5 5)'),
          ('geog_distance_cached_1c', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5 5)'),
          ('geog_distance_cached_1e', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5 5)'),
          ('geog_distance_cached_1f', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5 5)'),
          ('geog_distance_cached_1g', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5 5)'),
          ('geog_distance_cached_1h', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5 5)')
          ) AS u(c,ply,pt);
  2021-12-04 20:31:28.833 EST [1047] LOG:  terminating any other active server processes
  2021-12-04 20:31:28.833 EST [8837] WARNING:  terminating connection because of crash of another server process
  2021-12-04 20:31:28.833 EST [8837] DETAIL:  The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
  2021-12-04 20:31:28.833 EST [8837] HINT:  In a moment you should be able to reconnect to the database and repeat your command.
  2021-12-04 20:31:28.842 EST [98] WARNING:  terminating connection because of crash of another server process
  2021-12-04 20:31:28.842 EST [98] DETAIL:  The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
  2021-12-04 20:31:28.842 EST [98] HINT:  In a moment you should be able to reconnect to the database and repeat your command.
  2021-12-04 20:31:28.852 EST [1047] LOG:  all server processes terminated; reinitializing
  2021-12-04 20:31:29.116 EST [5701] LOG:  database system was interrupted; last known up at 2021-12-04 20:31:23 EST
  2021-12-04 20:31:29.293 EST [5701] LOG:  database system was not properly shut down; automatic recovery in progress
  2021-12-04 20:31:29.294 EST [5701] LOG:  redo starts at 0/8E5349C0
  2021-12-04 20:31:29.485 EST [5701] LOG:  invalid record length at 0/8F1323E0: wanted 24, got 0
  2021-12-04 20:31:29.485 EST [5701] LOG:  redo done at 0/8F131F48
  2021-12-04 20:31:29.485 EST [5701] LOG:  last completed transaction was at log time 2021-12-04 20:31:28.541784-05
  2021-12-04 20:31:29.549 EST [1047] LOG:  database system is ready to accept connections
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20211204/7b388c72/attachment.sig>
