[postgis-devel] ST_PointOnSurface calculation
Imre Samu
pella.samu at gmail.com
Wed Feb 3 19:53:44 PST 2021
> I've updated the manual page
Thanks !
> Any further suggestions? (Diagrams would be good, I know)
just for brainstorming, from a beginner mind.
No problem if these ideas are rejected.
#1.
Adding ST_MaximumInscribedCircle to the "See also"
reason: in my mind - this is similar like the "Circle on Polygon"
problem
#2.
in the tutorial page [1] 19.1. ST_Centroid / ST_PointOnSurface
.. there is an example diagram, maybe it can be reused ...
[1]
https://postgis.net/workshops/postgis-intro/geometry_returning.html#st-centroid-st-pointonsurface
or it is possible to crosslink the tutorial page [1] ?
#3. reusing the geometry from [1] .. we can create an example ..
when the ~3 center like example is different.
SELECT
ST_AsText(ST_Centroid(geom)) AS "centroid",
ST_AsText(ST_PointOnSurface(geom)) AS "pointOnSurface",
ST_AsText((SELECT center FROM ST_MaximumInscribedCircle(geom))) AS
"center_maximumInscribedCircle" -- postgis >= 3.1 Geos >=3.9
FROM (VALUES
('POLYGON ((30 0, 30 10, 10 10, 10 40, 30 40, 30 50, 0 50, 0 0, 0 0, 30
0))'::geometry)
) AS t(geom);
| centroid | pointOnSurface |
center_maximumInscribedCircle |
| POINT(11.666666666666666 25) | POINT(5 25) | POINT(5.859375 5.859375)
(1 row)
Regards,
Imre
Martin Davis <mtnclimb at gmail.com> ezt írta (időpont: 2021. febr. 4., Cs,
1:41):
> I've updated the manual page:
> https://postgis.net/docs/manual-dev/ST_PointOnSurface.html
> On Mon, Feb 1, 2021 at 10:15 PM Paolo Cavallini <cavallini at faunalia.it>
> wrote:
>> Hi all,
>> the description of the function is scanty. I always assumed it
>> calculated the point within a polygon closest to the centorid, but I
>> read it may not be so:
>> https://gis.stackexchange.com/questions/76498/how-is-st-pointonsurface-calculated
>> Is this confirmed?
>> In case, I suggest describing it in the manpage.
>> Thanks for any clarification.
>> Cheers.
>> Paolo Cavallini
>> www.faunalia.eu - QGIS.org
>> training, support, development on QGIS, PostGIS and more
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210204/3b4cfc43/attachment.html>
