[postgis-devel] Docker CI Images
rmrodriguez at carto.com rmrodriguez at carto.com
Mon Jan 4 23:20:13 PST 2021
The problem is that it's failing to preload the sanitizer libraries
(see https://travis-ci.org/github/pramsey/postgis/jobs/752836214#L275).
I'm guessing that clang was updated in the image, which means that the
path in the build
(https://github.com/postgis/postgis/blob/a4cc12b6fc56b1ccb03a620dee478f839ce83733/ci/travis/run_usan_clang.sh#L13)
needs to be updated too.
On Mon, Jan 4, 2021 at 8:51 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Have you seen this error before?
> https://travis-ci.org/github/pramsey/postgis/jobs/752836214#L2140
> Something about clang / sanitize is not happy?
> P
> > On Jan 3, 2021, at 8:30 PM, Daniel Baston <dbaston at gmail.com> wrote:
> > I published a new batch of images; you can see them here:
> > https://hub.docker.com/r/postgis/postgis-build-env/tags?page=1&ordering=last_updated
> > You'd need to update the Travis configuration to use the new 3.9 ones:
> > https://github.com/postgis/postgis/blob/master/.travis.yml#L8
> > Dan
> > On Sun, Jan 3, 2021 at 6:09 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> > Who runs the docker CI images? Can we get the ones with stable GEOS pushed forward to latest stable?
> > https://trac.osgeo.org/postgis/ticket/4823#comment:3
> > Thanks,
> > P
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
Raúl Marín Rodríguez
carto.com
