[postgis-devel] Make "master" branch also available as "main"
Darafei "Komяpa" Praliaskouski me at komzpa.net
Wed Jan 13 14:18:20 PST 2021
Hey, the point of the thing is not to add a thing called "main" but to get
rid ot the thing called "master" which your plan fails to accomplish. If we
go there, go all-in.
чц, 14 сту 2021, 01:08 карыстальнік Sandro Santilli <strk at kbt.io> напісаў:
> Following a recent chat on IRC about a motion, on mapserver-dev
> mailing list, for renaming the "master" branch to "main", to
> avoid a word which "trivializes a horrific time in history by
> re-using the conceptual framework of legalized human ownership for
> piddly computer stuff", I've been studying solutions that would make
> such transition less painful then when we decided to rename the
> main branch from "trunk" to "master"...
> Doing a simple rename would entail:
>   - Changing all "master" references in CI badges
>     (in the README.md of each branch, and on the wiki)
>   - Changing all "master" references in CI configurations
>   - Updating all developers clones remotes HEAD refenrece
>     to point to the new branch
>   - Updating all pull requests on all git hosters to still
>     point at the main branch (optional, for mirrors, as we
>     merge those ones manually anyway).
> The above can be painful, but what if we can have the _same_ branch
> referenced as both "main" and "master" until all of the above is done ?
> Well, the good new is that WE CAN !
> The `git` tool supports "symbolic references", so we could keep a
> "refs/heads/master" reference be a kind of symbolic link to
> "refs/heads/main", so that all users will see 2 branches ("master"
> and "main") and will be able to push to any of the two while seeing
> the change effectively applied to both.
> Such "symbolic references" are not supported by the git protocol,
> so they cannot be created on a remote from the client, but we DO
> have access to our official repository (we would NOT have this, if
> our official repository was on GitHub) so we can do this.
> I've done this "symbolic reference" setup on a staging host at osgeo:
>   https://dev.git.osgeo.org/gitea/postgis/postgis
> You'll see that the default branch there is called "main".
> If you clone that repository your local clone will have the "main"
> branch checked out. But you'll also see a "main" branch, and whether
> you push to "main" or to "master", your changes will be visible in
> both branches.
> Mirroring should still work, even if mirroring will loose symbolic
> references (references will become "hard"). On mirrors this should not
> be a problem because branches in mirrors are always overridden by the
> mirroring script, so it doesn't matter.
> So, would you like me to do this in production ?
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210114/71c1615f/attachment.html>
