[postgis-devel] PostGIS 3 and MobilityDB
Esteban Zimanyi
esteban.zimanyi at ulb.be
Sat Jul 3 00:49:05 PDT 2021
Dear Paul,
Many thanks for your reply. May I kindly ask you guidance on how to
implement the solution you suggested?
We will closely follow any futur change in liblwgeom's public API and
perform any required adaptation in MobilityDB code.
Regards
Esteban
On Fri, Jul 2, 2021, 18:15 Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> The simplest expedient is to vendor in a versioned copy of liblwgeom.h and
> then trust us when we pinky-swear that the we don't change the public API
> between releases.
> P
> > On Jul 2, 2021, at 8:34 AM, Esteban Zimanyi <esteban.zimanyi at ulb.be>
> wrote:
> > Alas MobilityDB only works with PostGIS 2.5. It was never possible to
> upgrade to version 3 since liblwgeom.h is not exported anymore.
> > On Fri, Jul 2, 2021, 17:23 Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > > On Jun 25, 2021, at 2:38 AM, Esteban Zimanyi <ezimanyi at ulb.ac.be>
> wrote:
> > > Now that our user base has considerably increased, we are continuously
> receiving the same question "What about PostGIS 3.1 support?"
> > I'm not sure I even understand the thrust of the question... what about
> it? Nothing has changed substantially in 3.1 in terms of code structure,
> etc. Why are not the same things you are doing with earlier versions
> working for 3.1?
> > P.
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210703/a12f0872/attachment.html>
