[postgis-devel] [SoC] GSoC 2021 - Week 3 Report - Implement pre-sorting methods before GiST index building
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Sun Jun 27 08:55:58 PDT 2021
On Sun, Jun 27, 2021 at 5:55 PM Han Wang <hanwgeek at gmail.com> wrote:
> Hi all,
> I am here to share with you my Week3 report. You can also find it at [1]
> *Coding Phase *:
> - Refactor the code structure, moving the hash function to the
> inline module
> - Create a pull request and receive suggestions from the community and
> mentors[2]
> - Finish the morton hash function
> I used `interleave` to implement a Morton(z-order) hash. What's more, I
> try to return the `x` of a `BOX2DF` as the hash order of the geometry
> object.
> What is confusing is that the Hilbert hash, the morton hash and the simple
> `x` show little difference in the performance test. So I think it is
> necessary to augment our test dataset and use some read world data.
- Try something broken from the start, like hash(x). Does it become worse?
If not, something is terribly wrong in benchmark code.
- To check the ordering of the index, you can create an index and then
CLUSTER the table using that. Then ST_MakeLine(geom order by ctid) will
create a line that follows the objects in the order they're in the index.
- I hope you're using at least a couple millions of objects. If not, take
any OpenStreetMap country (I use Belarus usually), get it to the db
(osmium-tool and its osmium export -f pg is good) and index that.
> *Plans for next week*:
> - Create larger random data or use real-world data for testing
> - Evaluate the stability and efficiency of hash functions
> - Searching for a more efficient hash function
> If you have any questions or suggestions, please let me know.
> [1]
> https://trac.osgeo.org/postgis/wiki/ImplementSortingMethodsBeforeGistIndexBuilding
> [2] https://github.com/postgis/postgis/pull/619
> Best regards,
> Han
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
OSM BY Team - http://openstreetmap.by/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20210627/a7da8b0b/attachment.html>
