[postgis-devel] ST_AsMVTGeom() feature size limit
Marco Boeringa
marco at boeringa.demon.nl
Wed May 19 09:14:08 PDT 2021
I think this is a much more generic issue with any generalization vector
algorithm relying on crude minimum area filtering as part of its toolchain.
You see the effect in most current vector tile services, where e.g. a
highly forested country like Slovenia, is often displayed without
woodland polygons at low or medium zoom scales, despite the forest
coverage of the country likely being over 50% or more. Only when you
zoom in, do the forest patches pop-up in view. This is a consequence of
the highly detailed digitization of the forest polygons in Slovenia,
with many small patches as well, and a rather generic minimum area
filtering.
Most current approaches to solve this issue either rely on external
sources like Natural Earth for low zoom scale, with both hand drawn or
satellite derived low zoom data, or to process the vector data by
rasterizing it, and using raster processing algorithms to simplify and
generalize the data, subsequently converting it back to vector.
However, what is actually required to tackle such issues in a pure
vector based approach, is a process to dissolve records. However, that
has its own major issues and isn't straight forward as well with
OpenStreetMap data as a basis.
E.g. here in The Netherlands, many large forest areas are cut up in very
small (0.1 - 4 hectare) forest patches, that are actually physically
separated by a tiny gap where forest tracks and paths run through the
forest. This means that a dissolve process alone will fail to merge the
polygons, as they are not topologically connected. It requires a buffer
step to merge them.
Dissolving often works better for urban landuse areas, as at least tiny
"landuse=residential" areas representing single house plots - often
detailed governmental data being added in some countries or specific
cities - usually are topologically connected, and can be successfully
dissolved.
In order to solve the "woodland problem", I personally spend a very
significant amount of time and effort, to develop a new completely
vector based approach involving a complex hybrid toolchain of PostGIS
and ArcGIS geoprocessing tools, that involves a buffer & dissolve step
and multi-stage minimum area filtering and generalization. I showed some
of this in the 'openstreetmap-carto' repository, with some screenshots
of the resulting "woodland" polygons as well:
https://github.com/gravitystorm/openstreetmap-carto/issues/4110
This toolchain actually manages to cut down > 12M "forest polygons" for
the entire globe, to just over 1000 for "Z0" type rendering. More than 6
GB of complex polygon data, is in the process reduced to less than 3,5
MB, while retaining what I believe is a pretty acceptable result.
This approach has its own limitations though. It works only well for the
kind of data represented by forests or glaciers: data displayed largely
on its own on the lower zoom level scales, like Z0-Z11. You can't use it
to generalize dozens of landuse types for midzoom scale display, as the
buffering approach would cause issues with overlaps between landuses
(although simply dissolving without buffering will work for mid zoom
scale display and still significantly reduce the total number of
features...).
In addition, needless to say, the processing involved and the total
processing time needed for a toolchain like this, is very significant,
think a few days on slightly outdated, but professional workstation
level hardware. It it therefor best suited for "batch" type occasional
updating, not a continuously updated map, like most modern map systems
try to achieve.
Marco
Op 19-5-2021 om 00:31 schreef Paul Ramsey:
> I was interested to find that ST_AsMVTGeom drops features that fall below 1/2 a pixel in size.
> postgis30=# select st_astext(st_asmvtgeom('LINESTRING(10 10, 11 10)', 'LINESTRING(0 0, 16384 16384)'::geometry));
> st_astext
> (1 row)
> There's no configuration option to avoid this behaviour, and if you map a large enough area that your feature size falls below a pixel you end up with big blanks in your map. Have there been no complaints about this before?
> P.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
